查看: 1837|回复: 5
[飞鸟集] 获取文件MD5的两种方法
已领礼包: 8125个
发表于 2020-1-7 14:34:13 | 显示全部楼层 |阅读模式
方式1: 通过certutil命令获取:
  1. ;;;参数file --文件名
  2. (defun GetMD5FromFile (file / wsh res txt idx cmd)
  3.   (setq wsh (vlax-create-object "wscript.shell"))
  4.   (setq cmd (strcat "certutil -hashfile \""  file "\" MD5"))
  5.   (setq res (vlax-invoke wsh 'exec cmd))
  6.   (setq txt (vlax-invoke (vlax-get res 'stdout) 'readall))
  7.   (setq idx (VL-STRING-POSITION (ascii "\r") txt))
  8.   (setq txt (substr txt (+ idx 3)))
  9.   (setq idx (VL-STRING-POSITION (ascii "\r") txt))
  10.   (setq txt (substr txt 1 idx))
  11.   (vlax-release-object wsh)
  12.   txt
  13. )
方式2: 通过WindowsInstaller.installer类获取.
  1. (defun GetMD5 (file / HASH H COUNT I S V WCS WI)
  2.   (if
  3.     (or
  4.       (setq wcs (vlax-create-object "Aec32BitAppServer.AecScriptControl.1"))
  5.       (setq wcs (vlax-create-object "ScriptControl"))
  6.     )
  7.      (vlax-put-property wcs "language" "VBScript")
  8.   )
  9.   (setq wi (vlax-create-object "WindowsInstaller.installer"))
  10.   ;;  (setq size (vlax-invoke wi 'filesize file))
  11.   ;;  (setq version (vlax-invoke wi 'fileversion file))
  12.   (setq hash (vlax-invoke wi 'filehash file 0))
  13.   (setq count (vlax-get-property hash 'FieldCount))
  14.   (setq i 1)
  15.   (setq s "")
  16.   (repeat count
  17.     (setq v (vlax-get-property hash 'IntegerData i))
  18.     (setq v (rtos v 2 0))
  19.     (setq H (vlax-invoke wcs 'eval (strcat "hex(" v ")")))
  20.     (while (< (strlen H) 8)
  21.       (setq H (strcat "0" H))
  22.     )
  23.     (setq s (strcat s
  24.                     (substr H 7 2)
  25.                     (substr H 5 2)
  26.                     (substr H 3 2)
  27.                     (substr H 1 2)
  28.             )
  29.     )
  30.     (setq i (1+ i))
  31.   )
  32.   (vlax-release-object hash)
  33.   (vlax-release-object wcs)
  34.   (vlax-release-object wi)
  35.   s
  36. )
用法示例:
(getMD5FromFile "c:\\temp\\test.exe")
(getMD5 "c:\\temp\\test.exe")
已领礼包: 5295个
发表于 2020-1-7 16:15:19 | 显示全部楼层
存在就是合理的另一种说法
已领礼包: 4365个
发表于 2020-1-9 00:05:23 | 显示全部楼层
发表于 2020-5-15 08:31:48 | 显示全部楼层
想请问大师一个问题,往表格的单元格里插入块应该用什么函数,不胜感激。
已领礼包: 677个
发表于 2022-8-10 11:05:55 | 显示全部楼层
字符串的MD5怎么获取
已领礼包: 1194个
发表于 2026-1-5 07:59:05 | 显示全部楼层
学习一下两种方法。感谢分享。
GMT+8, 2026-11-2 22:14 , Processed in 0.564667 second(s), 39 queries , Gzip On.
