查看: 2147|回复: 4
[每日一码] C#读写ini文件
已领礼包: 58个
发表于 2020-1-27 11:04:50 | 显示全部楼层 |阅读模式
using System;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
using System.IO;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using  System.ComponentModel;
    public class IniHelper
        [DllImport("kernel32")]//返回0表示失败,非0为成功
        private static extern long WritePrivateProfileString(string section, string key, string val, string filePath);
        [DllImport("kernel32")]//返回取得字符串缓冲区的长度
        private static extern long GetPrivateProfileString(string section, string key, string def, StringBuilder retVal, int size, string filePath);
        /// <summary>
        /// 读取ini文件
        /// </summary>
        /// <param name="Section">名称</param>
        /// <param name="Key">关键字</param>
        /// <param name="defaultText">默认值</param>
        /// <param name="iniFilePath">ini文件地址</param>
        /// <returns></returns>
        [LispFunction("zgx:ini:getvalue")]
        public static string GetValue(ResultBuffer rb)
            TypedValue[] TB = rb.AsArray();
            string Section, Key, defaultText, iniFilePath;
            iniFilePath = TB[0].Value as string;
            Section = TB[1].Value as string;
            Key = TB[2].Value as string;
            defaultText = null;
            if (File.Exists(iniFilePath))
                StringBuilder temp = new StringBuilder(1024);
                GetPrivateProfileString(Section, Key, defaultText, temp, 1024, iniFilePath);
                if (temp.ToString() == "")
                { return null; }
                else
                { return temp.ToString(); }
            else
                return defaultText;
        /// <summary>
        /// 写入ini文件
        /// </summary>
        [LispFunction("zgx:ini:setvalue")]
        public static bool SetValue(ResultBuffer rb)
            //(string Section, string Key, string Value, string iniFilePath)
            //string Section, Key, defaultText, iniFilePath;
            string iniFilePath = TB[0].Value as string;
            string Section = TB[1].Value as string;
            string Key = TB[2].Value as string;
            string Value = TB[3].Value as string;
            var pat = Path.GetDirectoryName(iniFilePath);
            if (Directory.Exists(pat) == false)
                Directory.CreateDirectory(pat);
            if (File.Exists(iniFilePath) == false)
                File.Create(iniFilePath).Close();
long OpStation = WritePrivateProfileString(Section, Key, Value, iniFilePath);
            if (OpStation == 0)
                return false;
            else
                return true;
已领礼包: 2230个
发表于 2020-1-27 14:21:49 | 显示全部楼层
做个对论坛有益的人。
发表于 2021-5-29 22:09:21 | 显示全部楼层
谢谢楼主,这个正是我需要的
已领礼包: 15个
发表于 2021-6-25 09:09:16 | 显示全部楼层
学习,学习。
GMT+8, 2026-11-3 09:27 , Processed in 0.447577 second(s), 37 queries , Gzip On.
