查看: 1518|回复: 6
[每日一码] 带数字的字符串表的排序
发表于 2020-2-13 13:39:19 | 显示全部楼层 |阅读模式
  1. ;;Usage (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05"))
  2. ;;Return ("A1" "A9" "A10" "B2" "B05" "B11")
  3. (defun SortStringWithNumberAsNumber (ListOfString)
  4. ;;;Function Normalize (add 0 befor number) number in string
  5. ;;; Count normalize symbols set in variable count
  6.   (defun NormalizeNumberInString (str / ch i pat ret count buf)
  7.     (setq i        0
  8.           pat        '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
  9.           ret        ""
  10.           count        4 ;_Count normalize symbols
  11.     ) ;_ end of setq
  12.     (while (/= (setq ch (substr str (setq i (1+ i)) 1)) "")
  13.       (if (vl-position ch pat)
  14.         (progn
  15.           (setq buf ch) ;_ end of setq
  16.           (while
  17.             (vl-position (setq ch (substr str (setq i (1+ i)) 1)) pat)
  18.              (setq buf (strcat buf ch))
  19.           ) ;_ end of while
  20.           (while (< (strlen buf) count) (setq buf (strcat "0" buf)))
  21.           (setq ret (strcat ret buf))
  22.         ) ;_ end of progn
  23.       ) ;_ end of if
  24.       (setq ret (strcat ret ch))
  25.     ) ;_ end of while
  26.     ret
  27.   ) ;_ end of defun
  28.   (vl-load-com)
  29.   (mapcar '(lambda (x) (nth x ListOfString))
  30.           (vl-sort-i (mapcar 'NormalizeNumberInString ListOfString)
  31.                      '<
  32.           ) ;_ end of VL-SORT-I
  33.   ) ;_ end of mapcar
  34. ) ;_ end of defun
  1. ;;Usage (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05") nil)
  2. ;;With ignore case (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05") t)
  3. ;;  CAB added Ignore Case Flag as an argument
  4. ;;Return ("A1" "A9" "A10" "B2" "B05" "B11")
  5. (defun SortStringWithNumberAsNumber
  6.        (ListOfString IgnoreCase / NorStrs count)
  7. ;;;Function Normalize (add 0 befor number) number in string
  8. ;;; Count normalize symbols set in variable count
  9. ;;; CAB added count as an argument
  10.   (defun NormalizeNumberInString (str count / ch i pat ret buf)
  11.     (setq i   0
  12.           pat '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
  13.           ret ""
  14.     ) ;_ end of setq
  15.     (while (/= (setq ch (substr str (setq i (1+ i)) 1)) "")
  16.       (if (vl-position ch pat)
  17.         (progn
  18.           (setq buf ch) ;_ end of setq
  19.           (while
  20.             (vl-position (setq ch (substr str (setq i (1+ i)) 1)) pat)
  21.              (setq buf (strcat buf ch))
  22.           ) ;_ end of while
  23.           (while (< (strlen buf) count) (setq buf (strcat "0" buf)))
  24.           (setq ret (strcat ret buf))
  25.         ) ;_ end of progn
  26.       ) ;_ end of if
  27.       (setq ret (strcat ret ch))
  28.     ) ;_ end of while
  29.     ret
  30.   ) ;_ end of defun
  31.   ;;-------------------------------------------------
  32.   ;;  function to Count the longest number in string
  33.   ;;  CAB added to get the correct COUNT
  34.   (defun getcount (lst / count pat)
  35.     (setq count 0)
  36.     (setq pat '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9"))
  37.     (mapcar
  38.       '(lambda (str / i maxlen ch)
  39.          (setq i 0
  40.                maxlen 0
  41.          )
  42.          (while        (/= (setq ch (substr str (setq i (1+ i)) 1)) "")
  43.            (if (vl-position ch pat)        ; number
  44.              (setq maxlen (1+ maxlen))
  45.              (setq count  (max count maxlen)
  46.                    maxlen 0
  47.              )
  48.            )
  49.          )
  50.          (setq count (max count maxlen)) ;_<<< ADD 21.06.2007 by VVA
  51.        )
  52.       Lst
  53.     )
  54.     count
  55.   )
  56.   ;;===============================================
  57.   (setq        count        (GetCount ListOfString)
  58.         NorStrs        (mapcar        '(lambda (x) (NormalizeNumberInString x count))
  59.                         ListOfString
  60.                 )
  61.   )
  62.   (and IgnoreCase (setq NorStrs (mapcar 'strcase NorStrs)))
  63.   (mapcar '(lambda (x) (nth x ListOfString))
  64.           (vl-sort-i NorStrs '<)
  65.   )
  66. ) ;_ end of defun
  1. ;; Alphanumerical Sort  -  Lee Mac
  2. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters.
  3. (defun LM:alphanumsort (lst)
  4.   (mapcar (function (lambda (n) (nth n lst)))
  5.           (vl-sort-i (mapcar 'LM:splitstring lst)
  6.                      (function
  7.                        (lambda (a b / x y)
  8.                          (while
  9.                            (and
  10.                              (setq x (car a))
  11.                              (setq y (car b))
  12.                              (= x y)
  13.                            )
  14.                             (setq a (cdr a)
  15.                                   b (cdr b)
  16.                             )
  17.                          )
  18.                          (cond
  19.                            ((null x) b)
  20.                            ((null y) nil)
  21.                            ((and (numberp x) (numberp y)) (< x y))
  22.                            ((numberp x))
  23.                            ((numberp y) nil)
  24.                            ((< x y))
  25.                          )
  26.                        )
  27.                      )
  28.           )
  29.   )
  30. )
  31. ;; Split String  -  Lee Mac
  32. ;; Splits a string into a list of text and numbers
  33. (defun LM:splitstring (str)
  34.   (
  35.    (lambda (l)
  36.      (read
  37.        (strcat
  38.          "("
  39.          (vl-list->string
  40.            (apply
  41.              'append
  42.              (mapcar
  43.                (function
  44.                  (lambda (a b c)
  45.                    (cond
  46.                      ((= 92 b)
  47.                       (list 32 34 92 b 34 32)
  48.                      )
  49.                      ((or (< 47 b 58)
  50.                           (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  51.                           (and (= 46 b) (< 47 a 58) (< 47 c 58))
  52.                       )
  53.                       (list b)
  54.                      )
  55.                      ((list 32 34 b 34 32))
  56.                    )
  57.                  )
  58.                )
  59.                (cons nil l)
  60.                l
  61.                (append (cdr l) '(()))
  62.              )
  63.            )
  64.          )
  65.          ")"
  66.        )
  67.      )
  68.    )
  69.     (vl-string->list str)
  70.   )
  71. )
  1. (defun c:test ()
  2.   (MySort '("T2A" "AS10" "T10B" "T1" "T2" "AS2" "T10" "T1A" "AS1" "T10A" "T1B" "T2B"))
  3. ;|
  4.   ALE=====>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T10A" "T10B" "T1A" "T2A" "T1B" "T2B")
  5.   LM:=====>  ("AS1" "AS2" "AS10" "T1" "T1A" "T1B" "T2" "T2A" "T2B" "T10" "T10A" "T10B")
  6.   Antistar>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T1A" "T2A" "T10A" "T1B" "T2B" "T10B") desired result
  7.   CAB=====>  ("AS1" "AS2" "AS10" "T1" "T1A" "T1B" "T2" "T2A" "T2B" "T10" "T10A" "T10B")
  8. |;
  9.   )
  10. ;;  CAB 01/30/14
  11. (defun parseNum        (str / lst tnum tstr)
  12.   (mapcar
  13.     (function
  14.       (lambda (x)
  15.         (cond
  16.           ((< 47 x 58)                        ; number
  17.            (if tstr
  18.              (setq lst        (cons (vl-list->string (reverse tstr)) lst)
  19.                    tstr        nil
  20.              )
  21.            )
  22.            (if tnum
  23.              (setq tnum (cons x tnum))
  24.              (setq tnum (list x))
  25.            )
  26.           )
  27.           (t                                ; non-number
  28.            (if tnum
  29.              (setq lst        (cons (atoi (vl-list->string (reverse tnum))) lst)
  30.                    tnum        nil
  31.              )
  32.            )
  33.            (if tstr
  34.              (setq tstr (cons x tstr))
  35.              (setq tstr (list x))
  36.            )
  37.           )
  38.         )
  39.       )
  40.     )
  41.     (vl-string->list str)
  42.   )
  43.   (if tstr
  44.     (setq lst (cons (vl-list->string (reverse tstr)) lst))
  45.   )
  46.   (if tnum
  47.     (setq lst (cons (atoi (vl-list->string (reverse tnum))) lst))
  48.   )
  49.   (reverse lst)
  50. )
  51. (defun MySort (lst)
  52.   (mapcar '(lambda (x) (nth x lst))
  53.           (vl-sort-i (mapcar '(lambda(x) (ParseNum x)) lst)
  54.                      '(lambda (e1 e2)
  55.                         (if (= (car e1) (car e2))
  56.                           (if (= (cadr e1) (cadr e2))
  57.                             (< (caddr e1) (caddr e2))
  58.                             (< (cadr e1) (cadr e2))
  59.                           )
  60.                           (< (car e1) (car e2))
  61.                         )
  62.                       )
  63.           )
  64.   )
  65. )
  1. (defun mysort ( l )
  2.     (vl-sort l
  3.         (function
  4.             (lambda ( a b / x y )
  5.                 (if (= (car  a) (car  b))
  6.                     (< (cadr a) (cadr b))
  7.                     (progn
  8.                         (setq a (LM:splitstring (car a))
  9.                               b (LM:splitstring (car b))
  10.                         )
  11.                         (while
  12.                             (and
  13.                                 (setq x (car a))
  14.                                 (setq y (car b))
  15.                                 (= x y)
  16.                             )
  17.                             (setq a (cdr a)
  18.                                   b (cdr b)
  19.                             )
  20.                         )
  21.                         (cond
  22.                             (   (null x) b)
  23.                             (   (null y) nil)
  24.                             (   (and (numberp x) (numberp y)) (< x y))
  25.                             (   (numberp x))
  26.                             (   (numberp y) nil)
  27.                             (   (< x y))
  28.                         )
  29.                     )
  30.                 )
  31.             )
  32.         )
  33.     )
  34. )
  35. ;; Split String  -  Lee Mac
  36. ;; Splits a string into a list of text and numbers
  37. (defun LM:splitstring ( str )
  38.     (
  39.         (lambda ( l )
  40.             (read
  41.                 (strcat "("
  42.                     (vl-list->string
  43.                         (apply 'append
  44.                             (mapcar
  45.                                 (function
  46.                                     (lambda ( a b c )
  47.                                         (cond
  48.                                             (   (= 92 b)
  49.                                                 (list 32 34 92 b 34 32)
  50.                                             )
  51.                                             (   (or (< 47 b 58)
  52.                                                     (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  53.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  54.                                                 )
  55.                                                 (list b)
  56.                                             )
  57.                                             (   (list 32 34 b 34 32))
  58.                                         )
  59.                                     )
  60.                                 )
  61.                                 (cons nil l) l (append (cdr l) '(( )))
  62.                             )
  63.                         )
  64.                     )
  65.                     ")"
  66.                 )
  67.             )
  68.         )
  70.     )
  71. )
  1. ;|
  2. _$ (mysort '(("A.05" 12.34 "Regular") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular") ("A.10" 12.12 "BigSize") ("A.05" 12.55 "BigSize")))
  3. (("A.05" 12.34 "Regular") ("A.05" 12.55 "BigSize") ("A.10" 12.12 "BigSize") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular"))
  4. |;
  1. (setq lst (list "PN375-A10.dwg"
  2.       "PN375-A9.dwg"
  3.       "PN375-A04.dwg"
  4.       "PN375-A555.dwg"
  5.       "PN375-D1.dwg"
  6.       "PN375-D10.dwg"
  7.       "PN375-D14.dwg"
  8.       "PN375-D2.dwg"
  9.       "PN375-D22.dwg"
  10.       "PN375-D7r3.dwg"
  11.       "PN375-DB.dwg"
  12.       "PN375-DB10a.dwg"
  13.       "PN375-DB9.dwg"))
  14. (mapcar '(lambda(x)(terpri)(princ x))
  15.         (SortStringWithNumberAsNumber lst))
("PN375-A10.dwg" "PN375-A9.dwg" "PN375-A04.dwg" "PN375-A555.dwg" "PN375-D1.dwg" "PN375-D10.dwg" "PN375-D14.dwg" "PN375-D2.dwg" "PN375-D22.dwg" "PN375-D7r3.dwg" "PN375-DB.dwg" "PN375-DB10a.dwg" "PN375-DB9.dwg")
_$
PN375-A04.dwg
PN375-A9.dwg
PN375-A10.dwg
PN375-A555.dwg
PN375-D1.dwg
PN375-D2.dwg
PN375-D7r3.dwg
PN375-D10.dwg
PN375-D14.dwg
PN375-D22.dwg
PN375-DB.dwg
PN375-DB9.dwg
PN375-DB10a.dwg
("PN375-A04.dwg" "PN375-A9.dwg" "PN375-A10.dwg" "PN375-A555.dwg" "PN375-D1.dwg" "PN375-D2.dwg" "PN375-D7r3.dwg" "PN375-D10.dwg" "PN375-D14.dwg" "PN375-D22.dwg" "PN375-DB.dwg" "PN375-DB9.dwg" "PN375-DB10a.dwg")
_$
发表于 2020-2-13 16:36:15 | 显示全部楼层
疫情时刻,保持一颗安静的心做功课,赞!
已领礼包: 4365个
发表于 2020-2-15 00:00:50 | 显示全部楼层
已领礼包: 4365个
发表于 2020-2-17 00:00:46 | 显示全部楼层
已领礼包: 202个
发表于 2020-3-26 16:59:43 | 显示全部楼层
doslib有个函数,能对这种数字、字母混合的排序,很好用。
(dos_strsort lst -1)
结果为:
已领礼包: 396个
发表于 2020-3-27 07:36:47 | 显示全部楼层
很好的帖子,多谢分享了
已领礼包: 11个
发表于 2020-5-24 13:54:58 | 显示全部楼层
谢谢楼主!!!正在学习这方面的
GMT+8, 2026-11-4 03:03 , Processed in 0.751266 second(s), 41 queries , Gzip On.
