查看: 1102|回复: 1
[求助] vb.net在CAD画三维问题(已解决)
发表于 2020-2-19 13:51:30 | 显示全部楼层 |阅读模式
求高手指点
运行后只是一个二维图,不知哪有问题
On Error Resume Next
        acadApp = GetObject(, "AutoCAD.Application")
        If Err.Number Then
            Err.Clear()
            acadApp = CreateObject("AutoCAD.Application")
            If Err.Number Then
                MsgBox(Err.Description)
                Exit Sub
            End If
        End If
        acadApp.Visible = True
        acadApp.Documents.Add()
        acadDoc = acadApp.ActiveDocument
        acadApp.Visible = True '设|¨¨置?界?面?可¨|视o¨®
        acadApp.WindowState = AutoCAD.AcWindowState.acMax '设|¨¨置?界?面?最á?大䨮化¡¥
        AppActivate(acadApp.Caption) '显?示o?AutoCAD界?面?
        acadApp.ActiveDocument.Layers.Item(0).color = AutoCAD.AcColor.acRed
        Dim NewDirection(0 To 2) As Double
        NewDirection(0) = 1 : NewDirection(1) = 0.5 : NewDirection(2) = 0.5
        acadApp.ActiveDocument.ActiveViewport.Direction = NewDirection
        acadApp.ActiveDocument.ActiveViewport = acadApp.ActiveDocument.ActiveViewport
Dim c1(10) As AcadEntity
       Dim cpt(0 To 2) As Double
        Dim cl1(0 To 2) As Double
        Dim cl2(0 To 2) As Double
        Dim radius As Double
        Dim starp As Double
        Dim endp As Double
        radius = 20
        starp = 0
        endp = pi
        cpt(0) = 85 : cpt(1) = 60 : cpt(2) = 0
        cl1(0) = 105 : cl1(1) = 60 : cl1(2) = 0
        cl2(0) = 65 : cl2(1) = 60 : cl2(2) = 0
        c1(0) = acadApp.ActiveDocument.ModelSpace.AddArc(cpt, radius, starp, endp)
        c1(1) = acadApp.ActiveDocument.ModelSpace.AddLine(cl1, cl2)
       c1(0).color = AutoCAD.AcColor.acYellow
        c1(1).color = AutoCAD.AcColor.acYellow
         Dim skiving1 As Object
        skiving1 = acadApp.ActiveDocument.ModelSpace.AddRegion(c1)
        Dim taper As Double
        Dim height As Double
        Dim solidskiv As Object
        taper = 0
        height = 100
        solidskiv = acadApp.ActiveDocument.ModelSpace.AddExtrudedSolid(skiving1(0), height, taper)
 楼主| 发表于 2020-2-21 08:55:21 | 显示全部楼层
可以了
GMT+8, 2026-11-3 00:59 , Processed in 0.380621 second(s), 30 queries , Gzip On.
