查看: 2931|回复: 14
[求助] 画指定坡度线程序 优化
发表于 2020-2-27 15:43:20 | 显示全部楼层 |阅读模式
**老师,2015.01.28 写的画指定坡比线的程序很好用,对我自身而言,有部分功能不适合,想简化掉,详情论坛里的大大帮我改进下,十分感谢!
需求:
1、指定1:m 的坡比,不需要X%的坡比标注。
2、输入坡比后,若ESC取消的话,snapang 默认不为0了,是个小BUG。
3、如若可能的话,能否增加“已知斜线的坡比标注”?我需要的是“1:x”这种标注。
附 何老师的源代码
(defun c:xieLine()
  (initget "1 2")
  (setq a (getstring"\n输入坡度度量型式[(1:X)->1]or[(X%)->2]<1>"))
  (if (= a "") (setq a "1"))
    (if (= a "1")
      (xieline1)
      (if (= a "2")
          (xieline2)
(defun xieLine1(/ aa ps)
  (setvar "orthomode" 1)
  (setq aa (getstring "\n输入坡度<1:X>:"))
  (setq aa1 (atof aa))
  (setq aa1 (/ 1 aa1))
  (setq aa1 (atan aa1))
  (setvar "snapang" aa1)
  (setq ps (getpoint"\n输入起点:"))
  (command "line" ps pause)
  (setvar "snapang" 0)
  (setq ss (strcat "\n已按1:" aa "的坡度绘制了一条直线"))
  (princ ss)
  (prin1)
(defun xieLine2(/ aa ps)
  (setq aa (getstring "\n输入坡度<X%>:"))
  (setq aa1 (/ aa1 100))
  (setq ss (strcat "\n已按" aa "%的坡度绘制了一条直线"))
  (princ ss)
  (prin1)
(prompt "按给定坡值绘制直线,在命令行输入PD按提示操作即可,编程:**,2015.01.28")
发表于 2020-2-28 09:38:07 | 显示全部楼层
试试这个,中途任意时间按esc取消,拾取起点后按鼠标左键或右键或按键盘任意非功能键均可完成任务
(defun c:TT  ( / bd ang stp enp p1 gr p0)
   (vl-load-com)
   (setvar "nomutt" 1)
   (defun gxl-error  (fun)
      (setq *olderror* *error*
            *Function* fun)
      (defun *error*  (msg)
         (if *Function*
            (VL-CATCH-ALL-APPLY *Function*))
         (setq *error* *olderror*
               *olderror* nil
               *Function* nil))
      (princ))
   (defun re () (setvar "nomutt" 0) (redraw))
   (gxl-error 're)
   (if (= aa nil)(setq aa 1))
   (if (null (setq bd (getreal (strcat "输入坡度 1: <" (vl-princ-to-string aa) ">" ))))
      (setq aa aa)
      (setq aa bd))
   (setq ang (atan (/ 1 aa)))
   (setq stp (getpoint "\n输入或拾取起点:"))
   (setq p1 (polar stp ang 1e2))
   (while (not (member (car (setq gr (grread t 13 0))) '(2 3 25)))
      (redraw)
      (setq p0 (polar (cadr gr) (+ ang (/ pi 2)) 1e2))
      (setq enp (inters stp p1 p0 (cadr gr) nil))
      (grvecs (list -3 stp enp)))
   (entmake (list '(0 . "LINE") (cons 10 stp) (cons 11 enp)))
   (setq mip (mapcar '(lambda (x y) (/ (+ x y) 2)) stp enp))
   (entmake (list '(0 . "TEXT")
                  (cons 40 (/ (distance stp enp) 20))
                  (cons 1 (strcat "1:" (if (eq aa (fix aa))(rtos aa) (vl-princ-to-string aa))))
                  (cons 10 mip)
                  (cons 50 ang)
                  '(72 . 1)
                  (cons 11 mip)))
   (vla-put-Alignment (vlax-ename->vla-object (entlast)) 13)
   (redraw)
   (setvar "nomutt" 0)
   (princ))
 楼主| 发表于 2020-2-28 14:17:37 | 显示全部楼层
(defun  ...
这个跟我想要的差不多了,感谢大佬
不过这个有部分问题,输入TT后,不提示“输入坡度 1: <”   需要直接输入,无任何提示
这个部分能否给予改进?万分感谢
 楼主| 发表于 2020-2-28 14:24:02 | 显示全部楼层
(defun  ...
我搞错了,您弄的是动态输入,我想弄到命令栏
看了下,你的界面DYN那里处于关闭状态, 在第2行和第3行间加入下面这句 (setvar "DYNMODE" 1) 运行命令时光标处会有提示的,就不必去看命令行了  详情 回复 发表于 2020-2-28 15:12
发表于 2020-2-28 15:12:52 | 显示全部楼层
在第2行和第3行间加入下面这句
 楼主| 发表于 2020-2-28 15:32:45 | 显示全部楼层
在第2行和第3行间加入下面这句
嗯嗯,因为我个人习惯了命令行,所以DYN开着感觉不方便,不知道您能否帮我调整下?感谢感谢
发表于 2020-2-28 15:39:05 | 显示全部楼层
你的意思是命令行要提示“输入坡度....."?
 楼主| 发表于 2020-2-28 15:43:03 | 显示全部楼层
嗯嗯,就是这个意思
 楼主| 发表于 2020-2-28 15:44:34 | 显示全部楼层
我按下面这个,结合您的,我试着自己改,改不出来,没基础  ,后面空了自己得好好学习下
(defun c:PD()
  (setq aa (getstring "\n输入坡度1:m<m>:"))
  (princ ss)
  (prin1)
发表于 2020-2-28 15:48:24 | 显示全部楼层
   (vl-load-com)
   (setvar "DYNMODE" 0)
   (setvar "nomutt" 0)
            *Function* fun)
         (if *Function*
               *olderror* nil
               *Function* nil))
      (princ))
   (gxl-error 're)
   (if (null (setq bd (getreal (strcat "\n输入坡度 1: <" (vl-princ-to-string aa) ">" ))))
      (setq aa aa)
      (setq aa bd))
      (redraw)
                  (cons 10 mip)
                  (cons 50 ang)
                  '(72 . 1)
                  (cons 11 mip)))
   (redraw)
   (princ))
您好,输入负数,标注也是负数,标注想要正的怎么办?  详情 回复 发表于 2023-1-16 17:21
 楼主| 发表于 2020-2-28 15:50:14 | 显示全部楼层
   (vl-load-com)
非常感谢,
发表于 2020-2-28 21:19:32 | 显示全部楼层
学习一下,看看大神之作
发表于 2023-1-16 17:21:16 | 显示全部楼层
   (vl-load-com)
(cons 1 (strcat "1:" (vl-princ-to-string (abs aa))))  详情 回复 发表于 2023-1-20 10:56
发表于 2023-1-20 10:56:06 | 显示全部楼层
感谢回复!我在创建文字前面加了 (setq aa (abs aa)),也可以  详情 回复 发表于 2023-2-4 18:03
发表于 2023-2-4 18:03:47 | 显示全部楼层
GMT+8, 2026-11-22 07:45 , Processed in 0.278399 second(s), 37 queries , Gzip On, File On.
