楼主: aimisiyou
[原创] 排数字游戏
 楼主| 发表于 2020-3-3 18:51:24 | 显示全部楼层
顺带解决N皇后问题(都是多叉树裁枝查找过程,远算量都是爆炸式增长类型),对比网上的数列程序运行结果是正确的。
$ (defun f(n)
(defun check(nlst k)
  (setq i 0)
  (setq num (+ 1 (length nlst)))
  (setq slst (mapcar '(lambda (x) (list (setq i (+ i 1)) x)) nlst))
  (if (or (member k nlst) (= 0 (apply '*(mapcar '(lambda (y) (if (= (- num (car y)) (abs (- k (cadr y)))) 0 1)) slst))))  (setq vt nil) (setq vt t))
  vt
(setq j n flst nil)
(while (> j 0)
   (setq flst (cons (list j) flst))
   (setq j (- j 1))
(setq ii 1)
(while (< ii n)
  (setq bestlst nil)
               (foreach en flst
               (setq jj 1 valst nil)
               (while (<= jj n)
                      (if (check en jj)
                                  (progn
                                    (setq valst (cons (reverse (cons jj (reverse en))) valst))
                                            (setq jj (+ jj 1))
                                           (setq jj (+ jj 1))
               (setq bestlst (append valst bestlst))
(setq flst bestlst)
(setq ii (+ ii 1))
flst
F
_$ (f 4)
((3 1 4 2) (2 4 1 3))
_$ (f 5)
((1 3 5 2 4) (1 4 2 5 3) (2 4 1 3 5) (2 5 3 1 4) (3 1 4 2 5) (3 5 2 4 1) (4 1 3 5 2) (4 2 5 3 1) (5 2 4 1 3) (5 3 1 4 2))
_$ (f 6)
((5 3 1 6 4 2) (4 1 5 2 6 3) (3 6 2 5 1 4) (2 4 6 1 3 5))
_$ (f 7)
((1 3 5 7 2 4 6) (1 4 7 3 6 2 5) (1 5 2 6 3 7 4) (1 6 4 2 7 5 3) (2 4 6 1 3 5 7) (2 4 1 7 5 3 6) (2 5 7 4 1 3 6) (2 5 3 1 7 4 6) (2 5 1 4 7 3 6) (2 6 3 7 4 1 5) (2 7 5 3 1 6 4) (3 1 6 2 5 7 4) (3 1 6 4 2 7 5) (3 5 7 2 4 6 1) (3 6 2 5 1 4 7) (3 7 4 1 5 2 6) (3 7 2 4 6 1 5) (4 1 5 2 6 3 7) (4 1 3 6 2 7 5) (4 2 7 5 3 1 6) (4 6 1 3 5 7 2) (4 7 5 2 6 1 3) (4 7 3 6 2 5 1) (5 1 6 4 2 7 3) (5 1 4 7 3 6 2) (5 2 6 3 7 4 1) (5 3 1 6 4 2 7) (5 7 2 4 6 1 3) (5 7 2 6 3 1 4) (6 1 3 5 7 2 4) (6 2 5 1 4 7 3) (6 3 7 4 1 5 2) (6 3 5 7 1 4 2) (6 3 1 4 7 5 2) (6 4 7 1 3 5 2) (6 4 2 7 5 3 1) (7 2 4 6 1 3 5) (7 3 6 2 5 1 4) (7 4 1 5 2 6 3) (7 5 3 1 6 4 2))
_$ (f 8)
((8 4 1 3 6 2 7 5) (8 3 1 6 2 5 7 4) (8 2 4 1 7 5 3 6) (8 2 5 3 1 7 4 6) (7 5 3 1 6 8 2 4) (7 4 2 8 6 1 3 5) (7 4 2 5 8 1 3 6) (7 3 1 6 8 5 2 4) (7 3 8 2 5 1 6 4) (7 2 4 1 8 5 3 6) (7 2 6 3 1 4 8 5) (7 1 3 8 6 4 2 5) (6 8 2 4 1 7 5 3) (6 4 1 5 8 2 7 3) (6 4 2 8 5 7 1 3) (6 4 7 1 3 5 2 8) (6 4 7 1 8 2 5 3) (6 3 1 8 4 2 7 5) (6 3 1 8 5 2 4 7) (6 3 1 7 5 8 2 4) (6 3 5 8 1 4 2 7) (6 3 5 7 1 4 2 8) (6 3 7 4 1 8 2 5) (6 3 7 2 4 8 1 5) (6 3 7 2 8 5 1 4) (6 2 7 1 3 5 8 4) (6 2 7 1 4 8 5 3) (6 1 5 2 8 3 7 4) (5 8 4 1 3 6 2 7) (5 8 4 1 7 2 6 3) (5 7 1 4 2 8 6 3) (5 7 1 3 8 6 4 2) (5 7 2 6 3 1 4 8) (5 7 2 6 3 1 8 4) (5 7 2 4 8 1 3 6) (5 7 4 1 3 8 6 2) (5 3 1 7 2 8 6 4) (5 3 1 6 8 2 4 7) (5 3 8 4 7 1 6 2) (5 2 4 7 3 8 6 1) (5 2 4 6 8 3 1 7) (5 2 6 1 7 4 8 3) (5 2 8 1 4 7 3 6) (5 1 4 6 8 2 7 3) (5 1 8 6 3 7 2 4) (5 1 8 4 2 7 3 6) (4 8 1 5 7 2 6 3) (4 8 1 3 6 2 7 5) (4 8 5 3 1 7 2 6) (4 7 1 8 5 2 6 3) (4 7 3 8 2 5 1 6) (4 7 5 3 1 6 8 2) (4 7 5 2 6 1 3 8) (4 6 1 5 2 8 3 7) (4 6 8 3 1 7 5 2) (4 6 8 2 7 1 3 5) (4 2 5 8 6 1 3 7) (4 2 7 5 1 8 6 3) (4 2 7 3 6 8 1 5) (4 2 7 3 6 8 5 1) (4 2 8 6 1 3 5 7) (4 2 8 5 7 1 3 6) (4 1 5 8 2 7 3 6) (4 1 5 8 6 3 7 2) (3 8 4 7 1 6 2 5) (3 7 2 8 5 1 4 6) (3 7 2 8 6 4 1 5) (3 6 2 7 1 4 8 5) (3 6 2 7 5 1 8 4) (3 6 2 5 8 1 7 4) (3 6 4 2 8 5 7 1) (3 6 4 1 8 5 7 2) (3 6 8 2 4 1 7 5) (3 6 8 1 4 7 5 2) (3 6 8 1 5 7 2 4) (3 5 2 8 1 7 4 6) (3 5 2 8 6 4 7 1) (3 5 7 1 4 2 8 6) (3 5 8 4 1 7 2 6) (3 1 7 5 8 2 4 6) (2 8 6 1 3 5 7 4) (2 7 3 6 8 5 1 4) (2 7 5 8 1 4 6 3) (2 6 1 7 4 8 3 5) (2 6 8 3 1 4 7 5) (2 5 7 4 1 8 6 3) (2 5 7 1 3 8 6 4) (2 4 6 8 3 1 7 5) (1 7 4 6 8 2 5 3) (1 7 5 8 2 4 6 3) (1 6 8 3 7 4 2 5) (1 5 8 6 3 7 2 4))
_$ (length (f 1))
1
_$ (length (f 2))
0
_$ (length (f 3))
0
_$ (length (f 4))
2
_$ (length (f 5))
10
_$ (length (f 6))
4
_$ (length (f 7))
40
_$ (length (f 8))
92
_$ (length (f 9))
352
_$ (length (f 10))
724
_$
 楼主| 发表于 2020-3-4 20:59:58 | 显示全部楼层
aimisiyou 发表于 2020-3-2 20:34
;;;程序跑了近6个小时,得出(length (ff 11))=320208.不敢往12跑了,估计得好几个月。
_$ (defun ff (n) ...
不会编辑公式,贴张统计个数的图片吧。失误失误,那个系数为f(n)的一个上界,“即为”应是“”小于”。
GMT+8, 2026-11-22 08:57 , Processed in 0.238784 second(s), 10 queries , Gzip On, File On.
