查看: 1309|回复: 5
[求助] princ输出优化
发表于 2020-3-27 11:21:45 | 显示全部楼层 |阅读模式
大佬,这种输出方式有没有简单点的方法,看着太繁琐了,谢谢!
(princ A1)(princ "+")(princ Y1)(princ "+")(princ S1)(princ "*")(princ X1)(princ "+")(princ Y1)(princ "+")(princ B1)
已领礼包: 145个
发表于 2020-3-28 01:21:10 | 显示全部楼层
用下 RTOS , STRCAT 把字符串组合起来再显示
回复 支持 1 反对 0
已领礼包: 2个
发表于 2020-3-28 09:46:56 | 显示全部楼层
(strcat "A" "+" "Y1" "+" "s1" "*" "x1" "+" "r1" "+" "B")运行结果:"A+Y1+s1*x1+r1+B"(strcat "A" "+" "Y1" "+" "s1" "*" "x1" "+" "r1" "+" "B" “=”)运行结果:"A+Y1+s1*x1+r1+B ="
 楼主| 发表于 2020-3-31 10:36:05 | 显示全部楼层
yinchuan99001 发表于 2020-3-28 09:46
(strcat "A" "+" "Y1" "+" "s1" "*" "x1" "+" "r1" "+" "B")运行结果:"A+Y1+s1*x1+r1+B"(strcat "A" "+" " ...
你好,其中A,Y1........等都不是字符串是程序前面求出的具体数值,试了一下显示(参数类型错误: stringp 30)。大佬这种怎么弄
已领礼包: 2个
发表于 2020-3-31 11:29:33 | 显示全部楼层
数据类型要转换,数据转换成字符串类型。
已领礼包: 677个
发表于 2020-7-22 16:20:20 | 显示全部楼层
数据类型错误,就转换成相应类型的数据就不会出错了呀,rtos、atof这些不能浪费了啊。
GMT+8, 2026-11-4 17:28 , Processed in 0.525954 second(s), 38 queries , Gzip On.
