查看: 2537|回复: 1
[分享] 将你的应用程序升级到ARX 2021指南
发表于 2020-3-29 01:02:42 | 显示全部楼层 |阅读模式
Migration Guide > ObjectARX Migration Guide
Description
Information about how to update existing ObjectARX® applications to work with AutoCAD® 2021 is provided here.
AutoCAD 2021 is a binary breaking release and ObjectARX applications developed for AutoCAD 2020 and earlier releases will need to be recompiled. The following sections list API changes made to this release. If your application uses any of these APIs, you will need to update your code accordingly.
Deprecated ObjectARX API
Class
Declaration
Use Instead
int acedGetCfg(const ACHAR * sym, ACHAR * var, size_t len);
int acedSetCfg(const ACHAR * sym, const ACHAR * val);
AcCmColor
ACDBCORE2D_PORT Acad::ErrorStatus setBlue(Adesk::UInt8 blue) override;
Acad::ErrorStatus setRGB(Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue) override;
AcCmColor
ACDBCORE2D_PORT Acad::ErrorStatus setColor(Adesk::UInt32 color) override;
ACDBCORE2D_PORT Acad::ErrorStatus setRGB(Adesk::RGBQuad rgbquad) override;
ACDBCORE2D_PORT Acad::ErrorStatus setRGBM(Adesk::UInt32 rgbmValue) override;
AcCmColor
ACDBCORE2D_PORT Acad::ErrorStatus setColorMethod(AcCmEntityColor::ColorMethod eColorMethod) override;
setNone(), setByBlock(), setByLayer(), etc
AcCmColor
ACDBCORE2D_PORT Acad::ErrorStatus setGreen(Adesk::UInt8 green) override;
AcCmColor
ACDBCORE2D_PORT Acad::ErrorStatus setRed(Adesk::UInt8 red) override;
AcCmColor
ACDBCORE2D_PORT Adesk::UInt32 color() const;
ACDBCORE2D_PORT Adesk::RGBQuad getRGB() const override;
ACDBCORE2D_PORT Adesk::UInt32 getRGBM() const override;
AcCmColorBase
virtual Acad::ErrorStatus setBlue(Adesk::UInt8 blue) = 0;
virtual Acad::ErrorStatus setRGB(Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue) = 0;
AcCmColorBase
virtual Acad::ErrorStatus setColor(Adesk::UInt32 color) = 0;
virtual Acad::ErrorStatus setRGB(Adesk::RGBQuad rgbquad) = 0;
virtual Acad::ErrorStatus setRGBM(Adesk::UInt32 rgbmValue) = 0;
AcCmColorBase
virtual Acad::ErrorStatus setColorMethod(AcCmEntityColor::ColorMethod eColorMethod) = 0;
AcCmColorBase
virtual Acad::ErrorStatus setGreen(Adesk::UInt8 green) = 0;
AcCmColorBase
virtual Acad::ErrorStatus setRed(Adesk::UInt8 red) = 0;
AcCmColorBase
virtual Adesk::UInt32 color() const = 0;
virtual Adesk::RGBQuad getRGB() const = 0;
virtual Adesk::UInt32 getRGBM() const = 0;
AcCmComplexColor
virtual ACDBCORE2D_PORT Acad::ErrorStatus setBlue(Adesk::UInt8 blue);
Acad::ErrorStatus setRGB(Adesk::UInt32 rgbValue);
AcCmComplexColor
virtual ACDBCORE2D_PORT Acad::ErrorStatus setColor(Adesk::UInt32 color);
Acad::ErrorStatus setRGBM(Adesk::UInt32 rgbmValue);
AcCmComplexColor
virtual ACDBCORE2D_PORT Acad::ErrorStatus setColorMethod(AcCmEntityColor::ColorMethod eColorMethod);
AcCmComplexColor
virtual ACDBCORE2D_PORT Acad::ErrorStatus setGreen(Adesk::UInt8 green);
AcCmComplexColor
virtual ACDBCORE2D_PORT Acad::ErrorStatus setRed(Adesk::UInt8 red);
AcCmComplexColor
virtual ACDBCORE2D_PORT Adesk::UInt32 color() const;
Adesk::UInt32 getRGB() const;
Adesk::UInt32 getRGBM() const;
AcCmEntityColor
ACDBCORE2D_PORT Acad::ErrorStatus setRGB(Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue);
AcCmEntityColor
setRGBM(), setRGB(), or setCOLORREF()
AcCmEntityColor
ACDBCORE2D_PORT Acad::ErrorStatus setColorMethod(ColorMethod eColorMethod);
AcCmEntityColor
AcCmEntityColor
AcCmEntityColor
ACDBCORE2D_PORT Acad::ErrorStatus setTrueColor();
ACDBCORE2D_PORT AcCmEntityColor makeTrueColor() const;
AcCmEntityColor
ACDBCORE2D_PORT Acad::ErrorStatus setTrueColorMethod();
AcCmEntityColor
ACDBCORE2D_PORT AcCmEntityColor(ColorMethod eColorMethod);
ACDBCORE2D_PORT AcCmEntityColor();
AcCmEntityColor
getRGBM(), getRGB(), or getCOLORREF()
AcCmEntityColor
ACDBCORE2D_PORT Adesk::UInt32 trueColor() const;
AcCmEntityColor
ACDBCORE2D_PORT Adesk::UInt8 trueColorMethod() const;
ACDBCORE2D_PORT ColorMethod colorMethod() const;
AcCmEntityColor
static ACDBCORE2D_PORT Adesk::UInt32 lookUpRGB(Adesk::UInt8 colorIndex);
ACDBCORE2D_PORT AcCmEntityColor makeRGB(Adesk::ColorRef background_rgb = 0) const;
AcCmEntityColor
static ACDBCORE2D_PORT Adesk::UInt8 lookUpACI(Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue);
ACDBCORE2D_PORT Adesk::Int16 colorIndex() const;
AcCmEntityColor
AcDbHostApplicationServices
AcadInternalServices * acadInternalServices2();
AcString
int findOneOfRev(const ACHAR * psz) const;
ACBASE_PORT int findLast(
const ACHAR * psz,
int nEndPos = -1
) const;
AcString
int findRev(ACHAR ch) const;
int findLast(
ACHAR ch,
int nEndPos = -1
) const;
AcString
int findRev(const ACHAR * psz) const;
const ACHAR * psz,
int nEndPos = -1
) const;
AcString
int findRev(const AcString & acs) const;
int findLast(
ACHAR ch,
int nEndPos = -1
) const;
CAdUiPathname
static ACHAR GetLastCharacter(const AcString& s);
AcString methods directly
Changed ObjectARX API
Class
Previous Class
Declaration
Previous Declaration
ACUI_PORT bool AcUiFindContextHelpFullPath(LPCTSTR fileName, CString& fullPath);
ACUI_PORT BOOL AcUiFindContextHelpFullPath (
ACUI_PORT bool AcUiIsInputPending();
ACUI_PORT BOOL AcUiIsInputPending ();
bool ADUI_PORT AdUiRegisterTool(LPCTSTR lpszToolName, LPCTSTR lpszCommand, LPCGUID pID);
bool ADUI_PORT AdUiRegisterTool(LPCTSTR lpszToolName, LPCTSTR lpszCommand, CLSID* pID);
typedef AcEdSSGetFilter AcEdSSGetFilter2;
class AcEdSSGetFilter2 : public AcEdSSGetFilter;
typedef AcEdSSGetFilter AcEdSSGetFilter3;
class AcEdSSGetFilter3 : public AcEdSSGetFilter;
AcDbDatabaseReactor
virtual void headerSysVarChanged(const AcDbDatabase*, const ACHAR*, bool);
const AcDbDatabase* dwg,
const ACHAR* name,
Adesk::Boolean bSuccess
AcDbDatabaseReactor
virtual void objectErased(const AcDbDatabase*, const AcDbObject*, bool);
const AcDbObject* dbObj,
Adesk::Boolean bErased
AcDbObjectReactor
virtual void erased(const AcDbObject*, bool);
virtual void erased(const AcDbObject* dbObj, Adesk::Boolean bErasing);
AcEditorReactor
virtual void sysVarChanged(const ACHAR*, bool);
virtual void sysVarChanged(const ACHAR* varName, Adesk::Boolean success);
AcEditorReactor
virtual void toolbarBitmapSizeChanged(bool);
virtual void toolbarBitmapSizeChanged(Adesk::Boolean bLarge);
AcEditorReactor
virtual void toolbarBitmapSizeWillChange(bool);
virtual void toolbarBitmapSizeWillChange(Adesk::Boolean bLarge);
AcEditorReactor
virtual void undoSubcommandAuto(int, bool);
virtual void undoSubcommandAuto(int activity, Adesk::Boolean state);
AcEdSSGetFilter
AcEdSSGetFilter2
virtual void ssgetRolloverFilter(const AcDbFullSubentPath & subEntityPath, AcDbFullSubentPath & highlightPath);
AcEdSSGetFilter
AcEdSSGetFilter3
virtual void ssgetRolloverFilter(const AcDbFullSubentPath & subEntityPath, AcDbFullSubentPathArray & highlightPaths);
AcEdSSGetFilter
AcEdSSGetFilter4
virtual void beginSSGetCustomKeywordCallback(const ACHAR*);
AcEdSSGetFilter
AcEdSSGetFilter4
virtual void endNEntsel(Acad::PromptStatus returnStatus, const AcDbObjectId& pickedEntity, const AcGePoint3d& pickedPoint, ads_point xformres[4], struct resbuf ** refstkres, AcEdSelectionSetService& service);
AcEdSSGetFilter
AcEdSSGetFilter4
virtual void endSSGetCustomKeywordCallback(const ACHAR*);
AcEdSSGetFilter
AcEdSSGetFilter5
virtual void ssgetPreviewFilter(const AcDbFullSubentPathArray& subEntityPaths, AcDbFullSubentPathArray& highlightPaths);
AcGsConfig
virtual bool isHardwareAccelerationAvailable() const = 0;
virtual bool isHardwareAccelerationAvailable() = 0;
AcGsConfig
virtual bool isHardwareAccelerationEnabled() const = 0;
virtual bool isHardwareAccelerationEnabled() = 0;
AcGsConfig
virtual bool isHardwareAccelerationRecommended() const = 0;
virtual bool isHardwareAccelerationRecommended() = 0;
AcGsConfig
virtual bool isNoHardwareOverrideEnabled() const = 0;
virtual bool isNoHardwareOverrideEnabled() = 0;
AcPlPlotConfig
ACPL_PORT bool matchMediaSize(double page_x, double page_y, double printable_w, double printable_h, AcDbLayout::PlotPaperUnits units, bool bIsSheet, int dpi, const ACHAR* pTargetCanonicalName, ACHAR*& pNearestSizeName, ACHAR*& pLocalizedName, double& scaleFactor);
ACPL_PORT virtual bool matchMediaSize(
double page_x,
double page_y,
double printable_w,
double printable_h,
bool bIsSheet,
int dpi,
const ACHAR * pTargetCanonicalName,
ACHAR *& pNearestSizeName,
ACHAR *& pLocalizedName,
double & scaleFactor
AcPlPlotErrorHandler
ACPL_PORT void getCompanyString(AcString& pCompanyString) const;
ACHAR*& pCompanyString
) const;
ACPL_PORT void getProductString(AcString& pProductString) const;
ACHAR*& pProductString
) const;
ACPL_PORT void getProgramString(AcString& pProgramString) const;
ACHAR*& pProgramString
) const;
AcPublishUIReactor
virtual void PersistenceRegistryForAutoPublishDialog(const ACHAR* lpszRegRoot, bool bIsReadRegistry);
bool bIsReadRegistry = true
AcPublishUIReactor
virtual void PersistenceRegistryForExportOptionsDialog(const ACHAR* lpszRegRoot, bool bIsReadRegistry);
AcPublishUIReactor
AcPublishUIReactor2
virtual void PersistenceRegistryForPublishOptionsDialog(const ACHAR* lpszRegRoot, bool bIsReadRegistry);
virtual void PersistenceRegistryForPubishOptionsDialog(
AcRxVariable
ACDBCORE2D_PORT Acad::ErrorStatus setValue(const resbuf& value, void* ownerId = NULL, AcString* failReason = NULL, bool disableUndoRecording = false);
ACDBCORE2D_PORT Acad::ErrorStatus setValue(const resbuf& value, void* ownerId = NULL, AcString* failReason = NULL);
AcString
ACBASE_PORT AcString tokenize(const wchar_t* pszTokens, int& iStart) const;
ACBASE_PORT AcString tokenize(const wchar_t* pszTokens, int& iStart);
AcTrayItemBubbleWindowControl
ACAD_PORT AcTrayItemBubbleWindowControl(const CString& strTitle, const CString& strText, const CString& strHyperText = ACRX_T(""), const CString& strHyperLink = ACRX_T(""), const CString& strText2 = ACRX_T(""), const CString& strCheckboxText = ACRX_T(""), bool bIsChecked = false);
ACAD_PORT AcTrayItemBubbleWindowControl(const CString& strTitle, const CString& strText, const CString& strHyperText = ACRX_T(""), const CString& strHyperLink = ACRX_T(""), const CString& strText2 = ACRX_T(""));
CAcExtensionModule
bool Attached() const;
BOOL Attached ();
CAcExtensionModule
bool AttachInstance(HINSTANCE hExtInst);
BOOL AttachInstance (HINSTANCE hInst);
CAcExtensionModule
HINSTANCE DefaultResourceInstance() const;
HINSTANCE DefaultResourceInstance ();
CAcExtensionModule
HINSTANCE ModuleResourceInstance() const;
HINSTANCE ModuleResourceInstance ();
CAcUiTrueColorComboBox
COLORREF getColorByCargo(int cargo);
DWORD getColorByCargo (int cargo);
COLORREF getColorData(AcCmColor color);
DWORD getColorData (AcCmColor color);
CAdUiDockControlBar
void SetToolID(LPCGUID pCLSID);
void SetToolID(CLSID* pCLSID);
CAdUiPathname
static ACHAR GetSeparator();
ACHAR GetSeparator(void) const;
CAdUiPathname
static bool IsDeviceName(const wchar_t *);
inline bool IsDeviceName(const AcString& str) const;
inline bool IsDeviceName(const str) const; inline bool IsDeviceName(const AcString& str) const;
CAdUiPathname
static bool Unquote(AcString&);
static void Unquote(AcString&);
static void Unquote(CString&);
CAdUiPathname
static FS_TYPE GetFileSystem(AcString& vol_name);
FS_TYPE GetFileSystem(AcString& vol_name) const;
Removed ObjectARX API
Class
Declaration
Use Instead
Acad::ErrorStatus removeSSgetFilterInputContextReactor(
AcApDocument * pDoc,
AcEdSSGetFilter2 * pFilter
ACCORE_PORT Acad::ErrorStatus removeSSgetFilterInputContextReactor(
AcEdSSGetFilter * pFilter
Acad::ErrorStatus addSSgetFilterInputContextReactor(
AcEdSSGetFilter5 * pFilter
ACCORE_PORT Acad::ErrorStatus addSSgetFilterInputContextReactor(
AcEdSSGetSubSelectFilter * pFilter
AcEdSSGetFilter4 * pFilter
AcEdSSGetFilter3 * pFilter
Acad::ErrorStatus setAllowDuplicateSelection(
unsigned char flag
ACCORE_PORT Acad::ErrorStatus setAllowDuplicateSelection(
bool flag
class AcPublishUIReactor : public AcRxObject
AcApLayoutManager
virtual const ACHAR * findActiveTab();
virtual Acad::ErrorStatus getActiveTab(AcString & sName) = 0;
AcApLayoutManager
virtual ACHAR * getNextNewLayoutName(AcDbDatabase* useDb = nullptr);
virtual Acad::ErrorStatus generateNextNewLayoutName(AcString & sName, AcDbDatabase* useDb = nullptr) = 0;
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setPenIndex(RGBM* rgbm, Adesk::UInt16 penIndex);
AcCmEntityColor
static Acad::ErrorStatus setRed(RGBM* rgbm, Adesk::UInt8 red);
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setLayerIndex(RGBM* rgbm, Adesk::Int32 layerIndex);
Acad::ErrorStatus setLayerIndex(Adesk::Int32 layerIndex);
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setColorMethod(RGBM* rgbm, ColorMethod eColorMethod);
AcCmEntityColor
static Acad::ErrorStatus setGreen(RGBM* rgbm, Adesk::UInt8 green);
AcCmEntityColor
static Adesk::UInt32 trueColor(const RGBM* rgbm);
AcCmEntityColor
const Adesk::UInt8 mLUT[256][3];
AcCmEntityColor
static Acad::ErrorStatus setTrueColorMethod(RGBM* rgbm);
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setRGB(RGBM* rgbm, Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue);
AcCmEntityColor
static Acad::ErrorStatus setTrueColor(RGBM* rgbm);
AcCmEntityColor
static bool isByBlock(const RGBM* rgbm);
bool isByBlock() const;
AcCmEntityColor
static bool isByACI(const RGBM* rgbm);
bool isByACI() const;
AcCmEntityColor
static bool isByColor(const RGBM* rgbm);
bool isByColor() const;
AcCmEntityColor
static bool isByPen(const RGBM* rgbm);
AcCmEntityColor
static bool isByLayer(const RGBM* rgbm);
bool isByLayer() const;
AcCmEntityColor
static Adesk::UInt32 color(const RGBM* rgbm);
AcCmEntityColor
static Adesk::UInt8 blue(const RGBM* rgbm);
Adesk::UInt8 blue() const;
AcCmEntityColor
static ACDBCORE2D_PORT Adesk::Int16 colorIndex(const RGBM* rgbm);
AcCmEntityColor
static Adesk::UInt8 green(const RGBM* rgbm);
Adesk::UInt8 green() const;
AcCmEntityColor
static ColorMethod colorMethod(const RGBM* rgbm);
AcCmEntityColor
static bool isForeground(const RGBM* rgbm);
bool isForeground() const;
AcCmEntityColor
union RGBM {
Adesk::UInt32 whole;
Adesk::Int16 indirect;
struct {
Adesk::UInt8 blue,
green,
red,
colorMethod;
} mdata;
Adesk::Int32 mnIndirect32;
Adesk::Int32 indirect24() const;
AcCmEntityColor
static Adesk::UInt8 red(const RGBM* rgbm);
Adesk::UInt8 red() const;
AcCmEntityColor
static Acad::ErrorStatus setBlue(RGBM* rgbm, Adesk::UInt8 blue);
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setColorIndex(RGBM* rgbm, Adesk::Int16 colorIndex);
Acad::ErrorStatus setColorIndex(Adesk::Int16 colorIndex);
AcCmEntityColor
static ACDBCORE2D_PORT Acad::ErrorStatus setColor(RGBM* rgbm, Adesk::UInt32 color);
AcCmEntityColor
static bool isLayerOff(const RGBM* rgbm);
AcCmEntityColor
static bool isLayerFrozen(const RGBM* rgbm);
AcCmEntityColor
static bool isNone(const RGBM* rgbm);
AcCmEntityColor
static Adesk::UInt16 penIndex(const RGBM* rgbm);
AcCmEntityColor
static Adesk::Int32 layerIndex(const RGBM* rgbm);
AcDbField
ACDBCORE2D_PORT Acad::ErrorStatus getHyperlink(ACHAR** pszName, ACHAR** pszDescription, ACHAR** pszSubLocation, ACHAR** pszDisplayString, Adesk::Int32* pFlag) const;
ACDBCORE2D_PORT Acad::ErrorStatus getHyperlink(AcString * psName, AcString * psDescription, AcString * psSubLocation, AcString * psDisplayString, Adesk::Int32* pFlag) const;
template <size_t nDevLen, size_t nStyleLen> bool getDefaultPlotCfgInfo(ACHAR (&devName)[nDevLen], ACHAR (&styleName)[nStyleLen]);
virtual ACDBCORE2D_PORT void getDefaultPlotCfgInfo(AcString& devName, AcString& styleName);
virtual ACDBCORE2D_PORT bool getDefaultPlotCfgInfo(ACHAR * plotDeviceName, size_t nDevNameLen, ACHAR * plotStyleName, size_t nStyleNameLen);
AcEditorReactor
virtual ADESK_DEPRECATED void beginClose(AcDbDatabase*);
virtual void docCloseWillStart(AcDbDatabase*);
AcEdSSGetFilter5
class AcEdSSGetFilter5 : public AcEdSSGetFilter;
class AcEdSSGetFilter : public AcEdInputContextReactor;
AcPlPlotConfig
virtual ACPL_PORT Acad::ErrorStatus makeCustomMediaFromSizeDesc(
HT_Media_Size * pSize,
HT_Media_Description * pDesc,
bool bSameDriver,
bool bSavePC3,
const ACHAR * pSourceEntry,
const ACHAR * pSourceName,
ACHAR *& pCanonicalSizeName,
ACHAR *& pLocalizedSizeName,
ACHAR *& pPMPPath,
ACHAR *& pPC3Path,
int dpi,
AcPlPlotConfig
virtual ACPL_PORT unsigned long isCustomPossible(
double width,
double height,
bool bIsDimensional,
bool bIsSheet,
int dpi,
const ACHAR * pPC3Dir
) const;
AcPlPlotConfig
virtual ACPL_PORT HT_Plot_Config* plotConfig() const;
AcPlPlotConfigManager
virtual HT_Thin_Plot_Config_Manager* thinPltCfgMgr();
virtual HT_Error_Handler* errorHandler();
virtual HT_Error_Handler* acadErrorHandler();
AcString
ACBASE_PORT int findOneOf(
const ACHAR * psz
) const;
const ACHAR * psz,
int nStartPos = 0
) const;
AcString
ACBASE_PORT int find(
const ACHAR * psz
) const;
const ACHAR * psz,
int nStartPos = 0
) const;
CAcUiDialogBar
~CAcUiDialogBar ();
CAcUiDialogBar
void DoDataExchange(CDataExchange* pDX) override;
CAcUiDialogBar
CAcUiDialogBar ();
CAcUiDialogBar
LPCTSTR AppRootKey () override;
CAcUiDialogBar
class ACUI_PORT CAcUiDialogBar : public CAdUiDialogBar {
CAcUiDialogBar
CWnd *AppMainWindow () override;
CAcUiDialogBar
HINSTANCE AppResourceInstance () override;
CAdUiPathname
ADESK_DEPRECATED bool Open(FILE** fdp, const ACHAR * openmode);
Changed Enum
Declaration
enum {
BUBBLE_WINDOW_ERROR_NO_CREATE,
BUBBLE_WINDOW_ERROR_NO_ICONS,
BUBBLE_WINDOW_ERROR_NO_NOTIFICATIONS,
BUBBLE_WINDOW_CLOSE,
BUBBLE_WINDOW_TIME_OUT,
BUBBLE_WINDOW_HYPERLINK_CLICK,
BUBBLE_WINDOW_HYPERLINK_CLICK_CHECKED,
BUBBLE_WINDOW_DOCUMENT_DEACTIVATED
enum {
发表于 2020-3-29 22:23:19 | 显示全部楼层
全英文,看不懂哦
GMT+8, 2026-11-22 08:41 , Processed in 0.143516 second(s), 10 queries , Gzip On, File On.
