查看: 1318|回复: 1
[原创] 判断进程是否正在运行
发表于 2020-4-11 09:41:18 | 显示全部楼层 |阅读模式
  1. (defun $判断进程是否正在运行$ (name / qry rtn srv wmi jcs wql)
  2.   (if (and name (= (type name) 'str) (> (strlen name) 0))
  3.     (progn
  4.       (setq
  5.         wql (strcat "Select * from Win32_Process Where Name LIKE '"
  6.                     name
  7.                     "%'"                ;通配符
  8.             )
  9.       )
  10.       (if
  11.         (and wql
  12.              (setq wmi (vlax-create-object "wbemscripting.swbemlocator"))
  13.         )
  14.          (progn
  15.            (setq rtn
  16.                   (vl-catch-all-apply
  17.                     (function
  18.                       (lambda (/ lst pros)
  19.                         (set 'srv (vlax-invoke wmi 'connectserver))
  20.                         (SET 'qry
  21.                              (vlax-invoke
  22.                                (vlax-invoke wmi 'connectserver)
  23.                                'execquery
  24.                                wql
  25.                              )
  26.                         )
  27.                         (vlax-for itm qry
  28.                           (setq pros (vlax-get itm 'properties_))
  29.                           (vlax-for prp        pros
  30.                             (if        (= "name" (strcase (vlax-get prp 'name) t))
  31.                               (progn
  32.                                 (setq lst (cons (vlax-get prp 'value) lst))
  33.                                 (setq itm nil)
  34.                                 (setq prp nil)
  35.                                 (setq pros nil)
  36.                                 (vl-catch-all-apply
  37.                                   'vlax-release-object
  38.                                   (list qry)
  39.                                 )        ;释放掉
  40.                                 (vl-catch-all-apply
  41.                                   'vlax-release-object
  42.                                   (list srv)
  43.                                 )        ;释放掉
  44.                               )
  45.                             )
  46.                           )
  47.                         )
  48.                         lst
  49.                       )
  50.                     )
  51.                   )
  52.            )
  53.            (vlax-release-object wmi)        ;释放对象
  54.            (if (vl-catch-all-error-p rtn)
  55.              (prompt (vl-catch-all-error-message rtn))
  56.              (setq jcs rtn)
  57.            )
  58.          )
  59.       )
  60.     )
  61.   )
  62.   jcs
  63. )
  64. ($判断进程是否正在运行$ "qq")
还有没有比这个速度更快的方法?
评分
参与人数 1D豆 +5 收起 理由
/db_自贡黄明儒_ + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2020-4-11 10:52:52 | 显示全部楼层
这个难道慢吗?
GMT+8, 2026-11-4 17:29 , Processed in 0.901342 second(s), 32 queries , Gzip On.
