查看: 1248|回复: 1
[每日一码] 利用GUID做种子,生成随机数
发表于 2020-4-12 22:40:33 | 显示全部楼层 |阅读模式
  1. (defun GUID (/ tl g)
  2.   (if (setq tl (vlax-get-or-create-object "Scriptlet.TypeLib"))
  3.     (progn (setq g (vlax-get tl 'Guid))
  4.            (vlax-release-object tl)
  5.            (substr g 2 36)
  6.     )
  7.   )
  8. )
  9. ;;; ---------------------------------------------------------------------------------------
  10. ;;; Convert a base into an integer
  11. ;;; ---------------------------------------------------------------------------------------
  12. (defun Base->Int (s b / i m ex)
  13.   (or *digits*
  14.       (setq
  15.         *digits* (vl-string->list "0123456789ABCDEFGHIJKLMNOPQSTUVWXYZ")
  16.       )
  17.   )
  18.   (setq        m  (wcmatch s "-*")
  19.         s  (vl-string->list (vl-string-left-trim "-+" s))
  20.         i  0.0
  21.         ex 0
  22.   )
  23.   (while s
  24.     (setq i (+ (* i b) (vl-position (car s) *digits*))
  25.           s (cdr s)
  26.     )
  27.   )
  28.   (fix (if m
  29.          (- i)
  30.          i
  31.        )
  32.   )
  33. )
  34. (defun RandomFromGUID (/ G a b)
  35.   (setq        G (vl-string-translate "-" "3" (GUID))
  36.         a (float (Base->Int (substr G 1 18) 16))
  37.         b (float (Base->Int (substr G 19) 16))
  38.         G (/ a b)
  39.   )
  40.   (rem (/ G (expt 10. (fix (/ G 10)))) 1.)
  41. )
_$ (RANDOMFROMGUID)
0.770795
_$ (repeat 10 (princ "\n")(princ (RANDOMFROMGUID)))(princ)
0.789914
0.00697833
0.0190617
0.469959
0.836066
0.0928757
0.0569814
0.0795628
0.759452
0.6551120.655112
_$
已领礼包: 166个
发表于 2020-4-14 10:45:06 | 显示全部楼层
楼主辛苦啦!~~~~~~
GMT+8, 2026-11-4 07:21 , Processed in 0.571275 second(s), 31 queries , Gzip On.
