查看: 1690|回复: 4
[每日一码] 使用点监视器,动态绘制内存实体,拖动生成鱼骨线
发表于 2020-6-2 01:29:51 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (defun _callback (dynpt)
  3.     (redraw)
  4.     (xdrx-setpropertyvalue
  5.       spl
  6.       "setfitpoints"
  7.       (reverse (cons dynpt lst))
  8.       ;;设置拟合点
  9.     )
  10.     (setq pts (xdrx-getpropertyvalue spl "getpointsatdist" 500.0))
  11.     (mapcar '(lambda (x)
  12.                (setq v          (xdrx-getpropertyvalue spl "firstderiv" x)
  13.                      v1          (xdrx-vector-perpvector v)
  14.                      p1          (mapcar '+ x (xdrx-vector-product v1 500.0))
  15.                      p2          (mapcar '- x (xdrx-vector-product v1 500.0))
  16.                      pts1 (cons (list p1 p2) pts1)
  17.                )
  18.                (xdrx-grdraw 7 -1 p1 p2)
  19.              )
  20.             (cdr pts)
  21.     )
  22.     (setq tf t)
  23.     (xdrx-grdraw 1 -1 spl)
  24.     ;;显示内存实体
  25.   )
  26.   (if (and (setq p1 (getpoint "\n起点<退出>:"))
  27.            (setq p2 (getpoint p1 "\n下一点<退出>:"))
  28.       )
  29.     (progn (xdrx-pointmonitor "_callback")
  30.            (setq lst (list p2 p1))
  31.            (setq spl (xdrx-spline-make))
  32.            ;;创建内存DB实体
  33.            (while (setq p3 (getpoint (car lst) "\n下一点<退出>:"))
  34.              (setq lst (cons p3 lst))
  35.              (setq nums (xdrx-getpropertyvalue spl "numfitpoints"))
  36.              (setq tf nil)
  37.            )
  38.            (xdrx-pointmonitor)
  39.            (if (> (xdrx-getpropertyvalue spl "numfitpoints") nums)
  40.              (xdrx-setpropertyvalue spl "removefitpointat" (length lst))
  41.            )
  42.            ;;移除最后鼠标确认前最后一个拟合点
  43.            (setq pts (xdrx-getpropertyvalue spl "getpointsatdist" 500.0))
  44.            (mapcar '(lambda (x)
  45.                       (setq v         (xdrx-getpropertyvalue spl "firstderiv" x)
  46.                             v1         (xdrx-vector-perpvector v)
  47.                             p1         (mapcar '+ x (xdrx-vector-product v1 500.0))
  48.                             p2         (mapcar '- x (xdrx-vector-product v1 500.0))
  49.                             pts1 (cons (list p1 p2) pts1)
  50.                       )
  51.                       (xdrx-line-make p1 p2)
  52.                     )
  53.                    (cdr pts)
  54.            )
  55.            (redraw)
  56.            (xdrx-entity-make spl)
  57.            ;;从内存实体创建到数据库
  58.     )
  59.   )
  60.   (princ)
  61. )
发表于 2020-6-2 08:14:34 | 显示全部楼层
谢谢分享
发表于 2020-6-2 11:53:24 | 显示全部楼层
感觉这个代码用于放置铁轨枕木很有用处
发表于 2020-6-3 11:51:27 | 显示全部楼层
真好用,放点用真不错
发表于 2020-6-3 12:52:30 | 显示全部楼层
GMT+8, 2026-11-22 10:06 , Processed in 0.272261 second(s), 18 queries , Gzip On, File On.
