查看: 2644|回复: 4
[求助] 如何用lisp调整子标准样式
已领礼包: 2个
发表于 2020-6-9 23:53:46 | 显示全部楼层 |阅读模式
已经用lisp创建了一个标注样式STDD,并生成了子标注样式,但是如何单独调整子标注样式呢?比如我想把子标注样式 半径的引线换成实心的箭头,如果我改"_DIMBLK"参数,那么其他标注子样式也会改变。 谢谢
  • (command-s "-dimstyle" "AN" "N" "STDD" "S" "")
  •       (command
  •         "_DIMADEC" "0"
  •         "_DIMALT" "0"
  •         "_DIMALTD" "2"
  •         "_DIMALTF" "25.4000"
  •         "_DIMALTRND" "0.0000"
  •         "_DIMALTTD" "2"
  •         "_DIMALTTZ" "0"
  •         "_DIMALTU" "2"
  •         "_DIMALTZ" "0"
  •         "_DIMAPOST" " "
  •         "_DIMASZ" "1"
  •         "_DIMATFIT" "3"
  •         "_DIMAUNIT" "0"
  •         "_DIMAZIN" "0"
  •         "_DIMBLK" "_ARCHTICK"
  •         "_DIMBLK1" " "
  •         "_DIMBLK2" " "
  •         "_DIMCEN" "1.8"
  •         "_DIMCLRD" "4"
  •         "_DIMCLRE" "4"
  •         "_DIMCLRT" "2"
  •         "_DIMDEC" "0"
  •         "_DIMDLE" "1"
  •         "_DIMDLI" "0.00"
  •         "_DIMDSEP" "."
  •         "_DIMEXE" "1.0"
  •         "_DIMEXO" "3.0"
  •         "_DIMFRAC" "0"
  •         "_DIMGAP" "1.5"
  •         "_DIMJUST" "0"
  •         "_DIMLDRBLK" ""
  •         "_DIMLFAC" "1.0000"
  •         "_DIMLIM" "0"
  •         "_DIMLUNIT" "2"
  •         "_DIMLWD" "-1"
  •         "_DIMLWE" "-2"
  •         "_DIMPOST" " " ;;标注测量值的后缀,例如MM、毫米
  •         "_DIMRND" "0.0000" ;;标注测量值舍入到指定值
  •         "_DIMSAH" "0"
  •         "_DIMSCALE" ScNum ;;标注字体、块的大小比例
  •         "_DIMSD1" "0"
  •         "_DIMSD2" "0"
  •         "_DIMSE1" "0"    ;;是否关闭第一条起、止界线
  •         "_DIMSE2" "0"   ;;是否关闭第二条起、止界线
  •         "_DIMSOXD" "0"
  •         "_DIMTAD" "1"
  •         "_DIMTDEC" "0"
  •         "_DIMTFAC" "1.0000"
  •         "_DIMTIH" "0"
  •         "_DIMTIX" "1"
  •         "_DIMTM" "0.0000"
  •         "_DIMTMOVE" "2"
  •         "_DIMTOFL" "1"
  •         "_DIMTOH" "0"
  •         "_DIMTOL" "0"
  •         "_DIMTOLJ" "1"
  •         "_DIMTP" "0.0000"
  •         "_DIMTSZ" "0.000"
  •         "_DIMTVP" "0.0000"
  •         "_DIMTXSTY" "TSSD-STD"
  •         "_DIMTXT" "3" ;;文字的高度
  •         "_DIMTZIN" "0"
  •         "_DIMUPT" "0"
  •         "_DIMZIN" "0")
  •   (if (not (tblsearch "dimstyle" "STDD$0")) (command-s "-dimstyle" "s" "STDD$0"))
  •   (if (not (tblsearch "dimstyle" "STDD$2")) (command-s "-dimstyle" "s" "STDD$2"))
  •   (if (not (tblsearch "dimstyle" "STDD$3")) (command-s "-dimstyle" "s" "STDD$3"))
  •   (if (not (tblsearch "dimstyle" "STDD$4")) (command-s "-dimstyle" "s" "STDD$4"))  ;;生成子标注样式  $2 角度标注,$3 直径标注  $4 半径标注,$6 坐标标注 $0 线性标注, $7 引线和公差
  •   (if (not (tblsearch "dimstyle" "STDD$7")) (command-s "-dimstyle" "s" "STDD$7"))
已领礼包: 51个
发表于 2020-6-10 05:27:47 | 显示全部楼层
设置样式替代
已领礼包: 2个
 楼主| 发表于 2020-6-11 22:00:29 | 显示全部楼层
谢谢指点,也就是每个子标注样式都使用样式替代的方式建立,对吧。没想到同一个系统变量可以让不同的子标注样式呈现不同的状态,比如 "_DIMBLK"变量。
去看下这个插件, http://bbs.xdcad.net/thread-726052-1-1.html  详情 回复 发表于 2020-6-11 22:02
是你每一个标注实体,都可以设置不同的  详情 回复 发表于 2020-6-11 22:01
已领礼包: 145个
发表于 2020-6-11 22:01:38 | 显示全部楼层
vpddup 发表于 2020-6-11 22:00
谢谢指点,也就是每个子标注样式都使用样式替代的方式建立,对吧。没想到同一个系统变量可以让不同的子标注 ...
是你每一个标注实体,都可以设置不同的
已领礼包: 145个
发表于 2020-6-11 22:02:57 | 显示全部楼层
去看下这个插件,
GMT+8, 2026-11-4 03:03 , Processed in 0.634191 second(s), 43 queries , Gzip On.
