查看: 2517|回复: 7
[已解决] xdrx-polyline-nearindex函数的用法
已领礼包: 202个
发表于 2020-6-20 15:56:35 | 显示全部楼层 |阅读模式
悬赏20D豆已解决
(xdrx-polyline-nearindex (car(entsel)) 2) 选取多段线,
这样用法不对吗?返回nil
最佳答案
查看完整内容
命令: (xdrx-getpropertyvalue (entlast)) ------ Geom Entity Method ------ : Edit Functions: ├───setCurveList Query Functions: ├───getCurveList ├───getCurveList ├───Vertices ├───Bulges ├───LineSegAt ├───ArcSegAt ├───PointAt ├───BulgeAt ├───isOnlyLines ...
已领礼包: 145个
发表于 2020-6-20 15:56:36 | 显示全部楼层
<kCompositeCrv3d>:
   Edit Functions:
        ├───setCurveList
   Query Functions:
        ├───getCurveList
        ├───getCurveList
        ├───Vertices
        ├───Bulges
        ├───LineSegAt
        ├───ArcSegAt
        ├───PointAt
        ├───BulgeAt
        ├───isOnlyLines
        ├───isOnlyArcs
        ├───hasBulges
        ├───OnSegAt
        ├───ToBox
        ├───NumVerts
        ├───globalToLocalParam
        ├───localToGlobalParam
<kCurve3d>:
   Bounding Box Functions:
        ├───boundBlock
        ├───orthoBoundBlock
   Closest Point Functions:
        ├───closestPointTo
        ├───projClosestPointTo
   Degeneracy Functions:
        ├───isDegenerate
   Distance Functions:
        ├───distanceTo
   Edit Functions:
        ├───setInterval
   Evaluation Functions:
        ├───evalPoint
   Geometric Inquiry Functions:
        ├───hasEndPoint
        ├───hasStartPoint
        ├───isClosed
        ├───isCoplannarWith
        ├───isLinear
        ├───isPeriodic
        ├───isPlannar
   Length Functions:
        ├───area
        ├───areaOf
        ├───length
        ├───paramAtLength
        ├───porintAtLength
   Parameterization Functions:
        ├───paramOf
        ├───reverseParam
   Point Containment Functions:
        ├───isOn
        ├───orthoProject
        ├───project
   Query Functions:
        ├───startParam
        ├───endParam
        ├───firstdeiv
        ├───firstderiv-
        ├───secondDeriv
        ├───secondDeriv-
        ├───getClosestPointTo
        ├───getInterval
        ├───getLocalClosestPoints
        ├───getNormalPoint
        ├───getProjClosestPointTo
        ├───getSamplePoints
        ├───getSplitCurves
        ├───getTrimmedOffset
   Subdivide Functions:
        ├───explode
<kEntity3d>:
   Equality Checking Functions:
        ├───isEqualTo
        ├───isOn
   Type Identification Functions:
        ├───isKindOf
        ├───type
------       DB Entity Method       ------
Class AcDb2dPolyline:
    ├─Closed
    ├─Thickness
    ├─Vertices
    ├─FeaturePoints
    ├─Elevation
    ├─DefaultEndWidth
    ├─DefaultStartWidth
    ├─isLinetypeGenerationOn
    ├─Normal
    ├─PolyType
    ├─AllInnerAngles
    ├─AllOuterAngles
    ├─Angle
    ├─AngularLineVector
    ├─AllSegs
    ├─SegAt
    ├─ArcSegs
    ├─ArcSegAt
    ├─ArcSegIndex
    ├─LineSegIndex
    ├─BulgeAt
    ├─Bulges
    ├─Elevation
    ├─ConstantWidth
    ├─Get
    ├─LineSegAt
    ├─Length
    ├─Lengths
    ├─HasBulges
    ├─HasPlinegen
    ├─HasWidth
    ├─InAngle
    ├─IsSelfCrossing
    ├─IsInnerAngle
    ├─IsOuterAngle
    ├─IsOnlyLines
    ├─NearIndex
    ├─Normal
    ├─NumVerts
    ├─OnSegAt(Point or (INT Point))    ├─PointAt
    ├─PrevNextIndex
    ├─-Index+
    ├─SelfIntPoints
    ├─SelfIntParams
    ├─Thickness
    ├─Vertices
    ├─FeaturePoints
    ├─WidthsAt
    ├─StartWidth
    ├─EndWidth
    ├─OutLine (NULL or Index or (Index and (Int or Real))
Class AcDbCurve:
    ├─Area
    ├─Centroid
    ├─DistanceTo
    ├─Divide
    ├─EndParam
    ├─EndPoint
    ├─GetClosestPointTo
    ├─GetFirstDeriv
    ├─GetFirstDeriv-
    ├─GetSecondDeriv
    ├─GetSecondDeriv-
    ├─GetPointAtParam
    ├─GetPointAtDist
    ├─GetPointsAtDist
    ├─GetPointsAtDists
    ├─GetParamAtPoint
    ├─GetParamAtDist
    ├─GetDistAtPoint
    ├─GetDistAtParam
    ├─GetSamplePoints
    ├─IsClosed
    ├─IsOn
    ├─IsPeriodic
    ├─MidPoint
    ├─StartPoint
    ├─StartParam
    ├─Length
Class AcDbEntity:
    ├─9PT
    ├─Centroid
    ├─GeomExtents
    ├─BoundingBox
    ├─Elevation
    ├─Color (None or T[real color])
    ├─ColorIndex (None or T)
    ├─ECS
    ├─IsMemoryEntity
    ├─Layer (None or T or NIL)
    ├─Layout
    ├─Linetype (None or T or NIL)
    ├─LinetypeScale
    ├─LineWeight
    ├─Project(Plane Normal T)
    ├─OrthoProject(Plane  T)
    ├─Plane
    ├─PlotStyleName
    ├─StretchPoint
    ├─Transparency
    ├─Visibility
Class AcDbObject:
    ├─ClassName
    ├─ExtensionDictionary
    ├─FieldDictionary
    ├─IsA
    ├─IsAProxy
    ├─IsErased
    ├─IsReallyClosing
    ├─Handle
    ├─HasFields
    ├─HasPersistentReactor
    ├─MyParent
    ├─ObjectID
    ├─Owner
    ├─xData
评分
参与人数 1D豆 +5 收起 理由
dyjwyqz5221 + 5 技术引导讨论和指点奖!
查看全部评分
已领礼包: 8644个
发表于 2020-6-20 16:42:52 | 显示全部楼层
这个确实有问题,我试了得用下面的才能得到正确的子段两端点
  1. (setq inx   (XD::Polyline:OnSegAt ePipe selpt)
  2.         inx1  (XD::PolyLine:-Index+ ePipe inx)
  3.         pps   (xdrx_getpropertyvalue ePipe "PointAt" inx)
  4.         ppe   (xdrx_getpropertyvalue ePipe "PointAt" (last inx1))
  5. )
还一种 命令: (xd::list:snakepair (xdrx-getpropertyvalue (entlast) "vertices")) (((4608.95 1180.75 0.0) (5540.47 1673.45 0.0)) ((5540.47 1673.45 0.0) (5339.56 2786.58 0.0)) ((5339.56 2786.58 0.0) (40  详情 回复 发表于 2020-6-20 18:34
已领礼包: 145个
发表于 2020-6-20 18:17:21 | 显示全部楼层
参数是 点
命令: (xdrx-polyline-nearindex poly (getpoint))
1
命令: (xdrx-getpropertyvalue poly "nearindex" (getpoint))
1
命令: (xdrx-getpropertyvalue poly "-index+" 2)
(1 3)
得到子段两点很多方法
(xdrx-getpropertyvalue (entlast) "divide" 1 t)
(((4608.95 1180.75 0.0) (5540.47 1673.45 0.0)) ((5540.47 1673.45 0.0) (5339.56 2786.58 0.0)) ((5339.56 2786.58 0.0) (4024.46 3407.02 0.0)))
命令: (xdrx-entity-getproperty (xdrx-getpropertyvalue (entlast) "allsegs") "get")
((((4608.95 1180.75 0.0) (5540.47 1673.45 0.0))) (((5540.47 1673.45 0.0) (5339.56 2786.58 0.0))) (((5339.56 2786.58 0.0) (4024.46 3407.02 0.0))))
(xdrx-entity-getproperty (xdrx-getpropertyvalue (entlast) "allsegs") "startpoint" "endpoint")
发表于 2020-6-20 18:32:03 | 显示全部楼层
函数功能是求 距离一个测试点 最近的 顶点索引,所以参数是点
不能是整数,距离顶点索引最近的顶点索引?
发表于 2020-6-20 18:34:40 | 显示全部楼层
还一种
评分
参与人数 1D豆 +5 收起 理由
查看全部评分
发表于 2020-6-20 18:36:51 | 显示全部楼层
尽可能的去用 xdrx-getpropertyvalue 吧,包括了N多功能了,替代了所有的对象的具体的函数
比如xdrx-polyline-xxxxx,  xdrx-line-xxxxx, xdrx-arc-xxxxx, xdrx-text-xxxx.......
已领礼包: 51个
发表于 2020-6-20 19:53:13 | 显示全部楼层
获取子段两端点
  1. (defun c:tt ()
  2.   (xdrx-begin)
  3.   (if (and (setq e (xdrx-entsel "\n拾取子段<退出>:" '((0 . "*polyline"))))
  4.            (setq p (cadr e)
  5.                  e (car e)
  6.            )
  7.            (setq seg (xdrx-getpropertyvalue e "segat" (trans p 1 0)))
  8.       )
  9.     (progn (mapcar '(lambda (x) (xdrx-grdraw 2 -1 x 3 4))
  10.                    (xdrx-getpropertyvalue seg "get")
  11.            )
  12.     )
  13.   )
  14.   (xdrx-end)
  15.   (princ)
  16. )
评分
参与人数 1D豆 +5 收起 理由
查看全部评分
GMT+8, 2026-11-3 13:57 , Processed in 0.460181 second(s), 46 queries , Gzip On.
