查看: 1317|回复: 2
[求助] 大师帮我看看,我这个程序好像有一点问题
发表于 2020-8-30 15:13:25 | 显示全部楼层 |阅读模式
;算出包围框
(defun ss::boundingbox (sel / idx llp ls1 ls2 obj urp)
    (repeat (setq idx (sslength sel))
      (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
      (if
    (and
      (vlax-method-applicable-p obj 'getboundingbox)
      (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp))))
     (setq ls1 (cons (vlax-safearray->list llp) ls1)
           ls2 (cons (vlax-safearray->list urp) ls2)
    (if (and ls1 ls2)
      (mapcar '(lambda (a b) (apply 'mapcar (cons a b))) '(min max) (list ls1 ls2))
;居中中心对齐
(defun c:dq ()        (setvar "OSMODE" 0)
       (princ "\n选择要移动的对象")
        (while (setq ss1 (ssget))
         (setq obj1 (ss::boundingbox ss1))
        (setq x (/ (+ (caar obj1) (caadr obj1)) 2))
        (setq y (/ (+ (cadar obj1) (cadadr obj1)) 2))
        (setq mid1 (list x y 0.0))
   (princ "\n选择对齐的对象")
          (setq ss2 (ssget))
         (setq obj2 (ss::boundingbox ss2))
         (setq x1 (/ (+ (caar obj2) (caadr obj2)) 2))
         (setq y1 (/ (+ (cadar obj2) (cadadr obj2)) 2))
         (setq mid2 (list x1 y1 0.0))
          (princ "\n中心对齐")
      (command "_.move" ss1 "" mid1 mid2))
     (setvar "OSMODE" 11)
    (princ)
8-30-.rar
36.19 KB, 下载次数: 3, 下载积分: D豆 -1 , 活跃度 1
发表于 2020-8-30 15:39:21 | 显示全部楼层
感觉是捕捉问题,一般用了command 控制捕捉就是耍流氓
谢谢大哥  详情 回复 发表于 2020-8-30 16:06
 楼主| 发表于 2020-8-30 16:06:55 | 显示全部楼层
谢谢大哥
GMT+8, 2026-11-4 06:22 , Processed in 0.568158 second(s), 38 queries , Gzip On.
