查看: 1099|回复: 1
[原创] Line Type Loading
已领礼包: 10个
发表于 2020-9-21 19:11:24 | 显示全部楼层 |阅读模式
You can use the following procedures to load linetypes. The LoadLineType (…) routine loads a specific linetype from the given linetype file, while the LoadLineTypes (...) routine loads all linetypes.
  1. public static void LoadLineType(this Database db, string LineTypeName, string LineTypeFileName)
  2. {
  3.     try
  4.     {
  5.         string path = HostApplicationServices.Current.FindFile(LineTypeFileName, db, FindFileHint.Default);
  6.         db.LoadLineTypeFile(LineTypeName, path);
  7.     }
  8.     catch (Autodesk.AutoCAD.Runtime.Exception ex)
  9.     {
  10.         if (ex.ErrorStatus == ErrorStatus.FilerError)
  11.             AcadApplication.Editor.WriteMessage("\n"{0}"  linetype file not found!", LineTypeFileName);
  12.         else if (ex.ErrorStatus == ErrorStatus.DuplicateRecordName)
  13.             AcadApplication.Editor.WriteMessage("\n"{0}"  linetype loaded!", LineTypeName);
  14.         else
  15.             AcadApplication.Editor.WriteMessage("\n{0} linetype failed to load: {1}", LineTypeName, ex.Message);
  16.     }
  17. }
  18. public static void LoadLineTypes(this Database db, string LineTypeFileName)
  19. {
  20.     try
  21.     {
  22.         string path = HostApplicationServices.Current.FindFile(filename, db, FindFileHint.Default);
  23.         db.LoadLineTypeFile("*", path);
  24.     }
  25.     catch (Autodesk.AutoCAD.Runtime.Exception ex)
  26.     {
  27.         if (ex.ErrorStatus == ErrorStatus.FilerError)
  28.             AcadApplication.Editor.WriteMessage("\n"{0}"  linetype file not found!", LineTypeFileName);
  29.         else if (ex.ErrorStatus == ErrorStatus.DuplicateRecordName)
  30.             AcadApplication.Editor.WriteMessage("\nLine types already loaded!");
  31.         else
  32.             AcadApplication.Editor.WriteMessage("\nErr: {0}", ex.Message);
  33.     }
  34. }
复制代码
发表于 2020-10-16 17:20:05 | 显示全部楼层
再写个使用实例多香呢
GMT+8, 2026-11-3 06:12 , Processed in 0.551792 second(s), 30 queries , Gzip On.
