查看: 1182|回复: 1
[求助] 选择集问题
发表于 2020-10-4 13:05:45 | 显示全部楼层 |阅读模式
(defun c:dd()
  (setvar "osmode" 32 )
  (setq x 1 )
  (setq y 1 )
  (setq r 0 )
  (setvar "osmode" 16383 )
  (command "insert" "daduan" (getpoint "捕捉交点") x y r )
  (setq ss (ssget "X" '(0."daduan")))
  (command "trim" refer "")
和下边的执行效果为何不一样
(defun c:dd()
  (setvar "cmdecho" 0)
  (setvar "osmode" 32)
  (setq radius 3)
  (setq refer (getpoint "捕捉交点"))
  (setvar "osmode" 16383)
  (command "circle" refer radius)
  (setq refer (entlast))
  (entdel refer)
 楼主| 发表于 2020-10-4 13:09:32 | 显示全部楼层
下边的是我自己编写的代码,意思是捕捉交点画圆然后打断
我想改成,通过插入块,确定裁剪边界,但是发现entlast无法选中插入的块
GMT+8, 2026-11-3 18:29 , Processed in 0.388707 second(s), 30 queries , Gzip On.
