查看: 1313|回复: 1
面积统计
发表于 2020-12-18 19:07:48 | 显示全部楼层 |阅读模式
求总面积源码,已实现框选,点选,配合F2查看面积总和,现想实现面积标注功能,求大侠修改一下。
;;MJ;;总面积
(defun c:MJ (/ olderr oldcmdecho errexit undox restore ss1 nr en tot_area) ;;总面积
(defun errexit (s)
(restore)
(defun undox ()
(command "._undo" "_E")
(setvar "cmdecho" oldcmdecho)
(setq *error* olderr)
(princ)
(setq olderr *error*
restore undox
*error* errexit
(setq oldcmdecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "._UNDO" "_BE")
(if (setq ss1 (ssget '((-4 . "<OR")
(0 . "POLYLINE")
(0 . "LWPOLYLINE")
(0 . "CIRCLE")
(0 . "ELLIPSE")
(0 . "SPLINE")
(0 . "REGION")
(-4 . "OR>")
(progn
(setq nr 0)
(setq tot_area 0.0)
(setq en (ssname ss1 nr))
(while en
(command "._area" "_O" en)
(setq tot_area (+ tot_area (getvar "area")))
(setq nr (1+ nr))
(princ "\n总面积 = ")
(princ tot_area)
(restore)
已领礼包: 915个
发表于 2020-12-21 00:00:52 | 显示全部楼层
生产力实用工具
GMT+8, 2026-11-3 00:54 , Processed in 0.410500 second(s), 30 queries , Gzip On.
