查看: 1213|回复: 0
[求助] 如何使用C#建立CAD与Excel之间“datalink”数据
发表于 2020-12-28 12:54:04 | 显示全部楼层 |阅读模式
论坛已有建立CAD与Excel之间“datalink”数据方法的代码,但是现在链接整个Excel工作表,如何实现链接工作表区域,比如工作表“A1:H7”区域。有没有大神给改一下,指点迷津,不胜感激。
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
namespace LinkToExcel
  public class Commands
    [CommandMethod("TFS")]
    static public void TableFromSpreadsheet()
      // Hardcoding the string
      // Could also select for it
      const string dlName =
        "Import table from Excel demo";
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      OpenFileDialog ofd =
        new OpenFileDialog(
          "Select Excel spreadsheet to link",
          null,
          "xls; xlsx",
          "ExcelFileToLink",
          OpenFileDialog.OpenFileDialogFlags.
            DoNotTransferRemoteFiles
      System.Windows.Forms.DialogResult dr =
        ofd.ShowDialog();
      if (dr != System.Windows.Forms.DialogResult.OK)
        return;
      ed.WriteMessage(
        "\nFile selected was \"{0}\".",
        ofd.Filename
      PromptPointResult ppr =
        ed.GetPoint(
          "\nEnter table insertion point: "
      if (ppr.Status != PromptStatus.OK)
        return;
      // Remove the Data Link, if it exists already
      DataLinkManager dlm = db.DataLinkManager;
      ObjectId dlId = dlm.GetDataLink(dlName);
      if (dlId != ObjectId.Null)
        dlm.RemoveDataLink(dlId);
      // Create and add the Data Link
      DataLink dl = new DataLink();
      dl.DataAdapterId = "AcExcel";
      dl.Name = dlName;
      dl.Description =
        "Excel fun with Through the Interface";
      dl.ConnectionString = ofd.Filename;
      dl.DataLinkOption =
        DataLinkOption.PersistCache;
      dl.UpdateOption |=
        (int)UpdateOption.AllowSourceUpdate;
      dlId = dlm.AddDataLink(dl);
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      using (tr)
        tr.AddNewlyCreatedDBObject(dl, true);
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId,
            OpenMode.ForRead
        Table tb = new Table();
        tb.TableStyle = db.Tablestyle;
        tb.Position = ppr.Value;
        tb.SetDataLink(0, 0, dlId, true);
        tb.GenerateLayout();
        BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            db.CurrentSpaceId,
            OpenMode.ForWrite
        btr.AppendEntity(tb);
        tr.AddNewlyCreatedDBObject(tb, true);
        tr.Commit();
      // Force a regen to display the table
      ed.Regen();
GMT+8, 2026-11-3 06:19 , Processed in 0.412226 second(s), 28 queries , Gzip On.
