查看: 1478|回复: 0
[原创] 发几个简化代码的函数
发表于 2021-1-7 15:59:18 | 显示全部楼层 |阅读模式
近日无事,写了点代码,供大家测试一下.
程序提供了3个文件,setup.lsp    vlapi.fas  vlapi.dvb,3个文件需要放在cad的搜索路径中.
Setup.lsp是源码,主要是检索和加载文件,一看就明白.
Vlapi.dvb是vba工程文件,提供数据返回功能,大家不用关心.
Vlapi.fas是编译后的文件,提供一下几个核心函数:
(Runvba strpro [value])
(with [str/vla-object])
(wget pro)
(wput pro value)
(wmeth method [vars])
(select var)
(case var)
(Runvba strpro [value])函数的用法:
(runvba"thisdrawing.ModelSpace(0)")>>> #<VLA-OBJECT IAcadLine000001a2be9a93b8>
(runvba"thisdrawing.ModelSpace(0).layer")>>>"AM_0"
(runvba"thisdrawing.ModelSpace(0).layer" "AM_5")>>>nil
(runvba"thisdrawing.ModelSpace(0).layer")>>>"AM_5"
还可以这样用:
(runvba "userform1.showvbmodeless")
(runvba"userform1.left" 100)
(with [str/vla-object])    (wget pro)      (wputpro value)   (wmeth method [vars]) 函数的用法:
这是一组函数,调用后三个函数前,需先用with函数,比如:
(with 'cadapp)或 (with“cadapp”)均返回#<VLA-OBJECT IAcadApplication00007ff61c25b910>
(with 'thisdrawing)返回#<VLA-OBJECT IAcadDocument 000001a2b0f97298>
(with (VLAX-GET-ACAD-OBJECT))返回#<VLA-OBJECT IAcadApplication 00007ff61c25b910>
(with "thisdrawing")返回"thisdrawing."
用法示例:
   (wget 'Name)或(wget “Name”)返回"Drawing1.dwg"
   (wget 'ModelSpace)或(wget“ModelSpace”)返回#<VLA-OBJECT IAcadModelSpace000001a2b0b841a8>
   (wget 'Width)或(wget”width”)返回1382
(with"thisdrawing.ModelSpace(0)")
   (wget 'layer)返回"AM_5"
   (wput 'layer "am_0")返回nil
   (wget 'layer)返回"AM_0"
(wmeth method [vars])函数的用法想必大家都明白了,只是其前面with函数的变量必须为vla-object类型
(select var)和(case var)的用法就很简单了,举例:
假如obj_line为vla-object类型的直线
(select (vla-get-color obj_line))
(Cond
   ((case 1) (princ “\n红色”))
   ((case 2) (princ “\n蓝色”))
vlapi.zip
9.74 KB, 下载次数: 17, 下载积分: D豆 -1 , 活跃度 1
评分
参与人数 1D豆 +5 收起 理由
marting + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-3 12:14 , Processed in 0.550447 second(s), 34 queries , Gzip On.
