查看: 4986|回复: 0
c# example for accessing the view table
发表于 2021-1-9 03:13:19 | 显示全部楼层 |阅读模式
问题:
Is there a c# (sharp) example that shows how to access views from .NET?
解答:
Here is an example that outputs the names of the views to the command line.
  1. // Namespaces in AutoCAD assemblies
  2. using Autodesk.AutoCAD.Runtime;
  3. using Autodesk.AutoCAD.ApplicationServices;
  4. using Autodesk.AutoCAD.DatabaseServices;
  5. using Autodesk.AutoCAD.EditorInput;
  6.   [Autodesk.AutoCAD.Runtime.CommandMethod("listViews")]
  7.   public void listViews()
  8.   {
  9.    Database db;
  10.    Transaction tr;
  11.    ViewTable vt;
  12.    ViewTableRecord vtRec;
  13.    Autodesk.AutoCAD.EditorInput.Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  14.    try
  15.    {
  16.     db = HostApplicationServices.WorkingDatabase;
  17.     using(tr = db.TransactionManager.StartTransaction())
  18.     {
  19.      using(vt = (ViewTable)tr.GetObject(db.ViewTableId, OpenMode.ForRead))
  20.      {
  21.       foreach(ObjectId id in vt)
  22.       {
  23.        vtRec = (ViewTableRecord)tr.GetObject(id, OpenMode.ForRead);
  24.        ed.WriteMessage("Name of View = " + vtRec.Name + "\n");
  25.       }
  26.      }
  27.      tr.Commit();
  28.     }
  29.    }
  30.    catch(System.Exception ex)
  31.    {
  32.     ed.WriteMessage(ex.ToString());
  33.    }
GMT+8, 2026-11-22 07:21 , Processed in 0.429477 second(s), 6 queries , Gzip On, File On.
