查看: 4454|回复: 2
Accessing LDATA values from VBA
发表于 2021-1-11 20:33:47 | 显示全部楼层 |阅读模式
问题:
A VLISP function can be used to create a dictionary just like:
(vlax-ldata-put "Test" "Helper" "Good")
And a dictionary named "Test" is created, and a (vlax-ldata-get "Test" "Helper")
retrieves the return value, "Good". From VBA, how can I get the dictionary data
value of "Good"?
解答:
VLISP ldata is attached to a custom object with class name "vlo_VL" and then the
object is added to the Named Object Dictionary. However, a custom object is not
penetrable by means of the VBA object model alone.  You cannot create custom
entities/objects with VBA, buty ou can develop custom entities with ObjectARX
and create an ActiveX interface to it so that it can be used within VBA.
Unfortunately, there is no direct interface (or Automation server) to a vlo_VL
object.
The AutoCAD 2000 Visual LISP Automation server (an unsupported interface) can be
used to bridge the gap between VBA macro and the LISP environment, though.
If the following has already been entered successfully at the command line:
(vl-load-com)
Then, with a little effort a VBA macro can use the LISP server's generalized
object model:
  1. Function readEvalHelper(app As Object)
  2.    ' this is a helper function
  3.    Set vld = app.ActiveDocument
  4.    Dim vlf_read As Object
  5.    Set vlf_read = vld.Functions.Item("read")
  6.    Dim vl_obj1 As Object
  7.    Set vl_obj1 = vlf_read.funcall("(defun read-eval (arg)(eval (read arg)))")
  8.    Dim vlf_eval As Object
  9.    Set vlf_eval = vld.Functions.Item("eval")
  10.    Dim vl_obj2 As Object
  11.    Set vl_obj2 = vlf_eval.funcall(vl_obj1)
  12. End Function
  13. Public Sub vlsGetLData()
  14.      Dim vlApp As Object
  15.      Set vlApp = CreateObject("VL.Application.1")
  16.      readEvalHelper vlApp
  17.      Dim invokeIt As Object
  18.      Set invokeIt = vlApp.ActiveDocument.Functions.Item("read-eval")
  19.      invokeIt.funcall ("(setq lDatum (vlax-ldata-get ""Test"" ""Helper""))")
  20.      Set sym = vlApp.ActiveDocument.Functions.Item("read").funcall("lDatum")
  21.      GetLispSym = vlApp.ActiveDocument.Functions.Item("eval").funcall(sym)
  22.      MsgBox ("Key's data is:" + Chr(13) + GetLispSym)
  23. End Sub
See also DevNote #30485 for more discussion and illustrated examples of how to
exploit Visual LISP Server.
发表于 2021-11-5 09:12:52 | 显示全部楼层
这个好像得改16
发表于 2022-3-27 07:50:41 | 显示全部楼层
感谢楼主分享!
GMT+8, 2026-11-22 07:19 , Processed in 0.376346 second(s), 6 queries , Gzip On, File On.
