- UID
- 5280
- 积分
- 9549
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-5-18
- 最后登录
- 1970-1-1
问题:
How do I add a block to a drawing through an ActiveX Client in C++?
解答:
There are two interface objects that are mirrored to their ObjectARX
counterparts: IAcadBlocks to AcDbBlockTable and IAcadBlock to
AcDbBlockTableRecord. You then need to get to the interface objects and call the
appropriate methods.
These are the key steps to doing this:
1. Create a standalone MFC AppWiard EXE that is dialog-based.
2. Use the ClassWizard to import the following interfaces (from acad.tlb) and
declare them as private member variables of the dialog class:
IAcadApplication m_IApp;
IAcadDocument m_IDoc;
IAcadBlock m_IBlock;
IAcadBlocks m_IBlocks;
3. In the dialog's OnInitDialog(), assign a separate button handler, and get
the application and document object (a button with handler code shown below).
 - void CClientDlg::OnStart()
- HRESULT hr = NOERROR;
- CLSID clsid;
- LPUNKNOWN pUnk = NULL;
- LPDISPATCH pDisp = NULL;
- BeginWaitCursor();
- CoInitialize(NULL);
- hr = ::CLSIDFromProgID(L"AutoCAD.Application", &clsid);
- if (SUCCEEDED(hr))
- if(::GetActiveObject(clsid, NULL, &pUnk) == S_OK)
- VERIFY(pUnk->QueryInterface(IID_IDispatch,(LPVOID*)&pDisp) == S_OK);
- m_IApp.AttachDispatch(pDisp);
- pUnk->Release();
- else
- VERIFY(m_IApp.CreateDispatch(clsid) == TRUE);
- m_IApp.SetVisible(TRUE);
- pDisp = m_IApp.GetActiveDocument();
- m_IDoc.AttachDispatch(pDisp);
- else
- AfxMessageBox("Acad.Application is not registered!");
- //CoUninitialize(); // do this in the dialog's exit code
- EndWaitCursor();
- 4. Create a button and its handler, then add the following code:
- void CClientDlg::OnAddBlock()
- VARIANT var;
- double pt[3] = {2, 2, 0};
- getVariantFromDblArray(&var, pt);
- const char blkName[] = "TEST";
- LPDISPATCH p = m_IDoc.GetBlocks();
- m_IBlocks.AttachDispatch(p);
- p = m_IBlocks.Add(var, blkName);
- m_IBlock.AttachDispatch(p);
- HRESULT getVariantFromDblArray(VARIANT* pVal, const double pt[3])
- pVal->vt = VT_ARRAY | VT_R8;
- SAFEARRAYBOUND rgsaBound;
- rgsaBound.lLbound = 0L;
- rgsaBound.cElements = 3;
- pVal->parray = SafeArrayCreate(VT_R8, 1, &rgsaBound);
- if (! pVal->parray)
- return E_OUTOFMEMORY;
- HRESULT hr;
- for (long i = 0; i < 3; i++)
- if ((hr = SafeArrayPutElement(pVal->parray, &i,
- (void*)&pt))!=S_OK)
- return hr;
- return S_OK;
