查看: 1271|回复: 1
[每日一码] 读取Internet上的文本文件
已领礼包: 20个
发表于 2021-1-13 19:48:51 | 显示全部楼层 |阅读模式
  1. (defun vk_GetRemoteText (RemoteFileName / objHTTP Result)
  2.     (if (setq objHTTP (vlax-create-object "WinHTTP.WinHTTPRequest.5.1"))
  3.         (progn (setq
  4.                    Result (vl-catch-all-apply
  5.                               (function
  6.                                   (lambda ()
  7.                                       (vlax-invoke-method
  8.                                           objHTTP       "Open"
  9.                                           "GET"         RemoteFileName
  10.                                           :vlax-false
  11.                                          )
  12.                                       (vlax-invoke objHTTP "Send")
  13.                                       (vlax-get-property objHTTP "ResponseText")
  14.                                   )
  15.                               )
  16.                           )
  17.                )
  18.                (vlax-release-object objHTTP)
  19.                (if (not (vl-catch-all-error-p Result))
  20.                    Result
  21.                )
  22.         )
  23.     )
  24. )
例如:(vk_GetRemoteText "http://abc.ocm/abc.txt")
已领礼包: 677个
发表于 2021-1-13 21:36:11 | 显示全部楼层
ocm应为com
GMT+8, 2026-11-3 12:15 , Processed in 0.448386 second(s), 31 queries , Gzip On.
