查看: 1639|回复: 0
[每日一码] 指定字符分割字符串
已领礼包: 20个
发表于 2021-1-13 19:54:42 | 显示全部楼层 |阅读模式
  1. (defun _split (str char / pos lst )
  2.   (while (vl-string-position (ascii char) str)
  3.           (setq lst (cons (substr str 1 (setq pos (vl-string-position (ascii char) str))) lst)
  4.                 str (substr str (+ 2 pos))
  5.           );end_setq
  6.   );end_while
  7.   (setq lst (vl-remove-if '(lambda (x) (= x "")) (reverse (cons str lst))))
  8. );end_defun
命令: (_split "abc,fafaf,efafa" ",")
("abc" "fafaf" "efafa")
GMT+8, 2026-11-3 13:57 , Processed in 0.453451 second(s), 29 queries , Gzip On.
