查看: 1280|回复: 0
[每日一码] 不使用第三方库读取GEOTIFF卫星影像生成WORD FILE
发表于 2021-1-13 21:08:11 | 显示全部楼层 |阅读模式
world file 是由地理信息系统(GIS)用于地理参考栅格地图图像的六行纯文本Sidecar文件。 文件规范由Esri [1] [2]引入,由仿射变换的六个系数组成,这些系数描述了地图上栅格的位置,比例和旋转.
  1. /// <summary>
  2.     /// Create tfw - world file.
  3.     /// </summary>
  4.     /// <param name="filename">tif image full filename</param>
  5.     private void CreateWorldFile(string filename)
  6.     {
  7.         using (var bitmapImage = new Bitmap(filename))
  8.         {
  9.             PropertyItem[] imageProps = bitmapImage.PropertyItems;
  10.             var modelscale = imageProps.First(a => a.Id == GEOTIFF_MODELPIXELSCALETAG);
  11.             var tiepoint = imageProps.First(a => a.Id == GEOTIFF_MODELTIEPOINTTAG);
  12.             double x = BitConverter.ToDouble(tiepoint.Value, 0 + 24);
  13.             double y = BitConverter.ToDouble(tiepoint.Value, 0 + 32);
  14.             double xscale = BitConverter.ToDouble(modelscale.Value, 0);
  15.             double yscale = BitConverter.ToDouble(modelscale.Value, 0 + 8);
  16.             string tfwFileName = Path.GetDirectoryName(filename) + "\\" + Path.GetFileNameWithoutExtension(filename) + ".tfw";
  17.             using (System.IO.StreamWriter file = new System.IO.StreamWriter(tfwFileName))
  18.             {
  19.                 file.WriteLine(xscale);
  20.                 file.WriteLine("0.0");
  21.                 file.WriteLine("0.0");
  22.                 file.WriteLine(yscale);
  23.                 file.WriteLine(x);
  24.                 file.WriteLine(y);
  25.             }
  26.         }
  27.     }
  28.     private readonly int GEOTIFF_MODELPIXELSCALETAG = 33550;
  29.     private readonly int GEOTIFF_MODELTIEPOINTTAG = 33922;
GMT+8, 2026-11-3 09:24 , Processed in 0.397159 second(s), 28 queries , Gzip On.
