查看: 1344|回复: 0
[每日一码] Entmake Ole2Frame Paitbrush image
发表于 2021-1-13 21:17:57 | 显示全部楼层 |阅读模式
  1. <LispFunction("FIMGOLE")> _
  2.     Public Function FIMGOLE(ByVal rbfArgs As ResultBuffer) As ResultBuffer
  3.         '
  4.         '>>>ARGUMENTOS DE ENTRADA
  5.         Dim arInputArgs As Array
  6.         arInputArgs = rbfArgs.AsArray
  7.         Dim MYIMG As String = CStr(CType(arInputArgs.GetValue(0), TypedValue).Value)
  8.         Dim MYANG As Single = CSng(CType(arInputArgs.GetValue(1), TypedValue).Value)
  9.         '
  10.         Dim IMGTMP As String = Path.GetDirectoryName(MYIMG) & "\myimg.jpg"
  11.         Dim IMG As System.Drawing.Image = New Bitmap(MYIMG)
  12.         Dim DW, DH As Integer
  13.         If MYANG = 0 Then
  14.             DW = 0
  15.             DH = 0
  16.         Else
  17.             DW = 5
  18.             DH = 5
  19.         End If
  20.         Dim retBMP As New Bitmap(IMG.Width + DW, IMG.Height + DH)
  21.         retBMP.SetResolution(IMG.HorizontalResolution, IMG.VerticalResolution)
  22.         Using g = Graphics.FromImage(retBMP)
  23.             g.Clear(Drawing.Color.White)
  24.             g.TranslateTransform(0, IMG.Height)
  25.             g.RotateTransform(MYANG)
  26.             g.TranslateTransform(0, -IMG.Height)
  27.             g.DrawImage(IMG, New PointF(0, 0))
  28.         End Using
  29.         retBMP.Save(IMGTMP, ImageFormat.Jpeg)
  30.         '
  31.         Dim imge As Drawing.Image = Bitmap.FromFile(IMGTMP)
  32.         Dim mem As New IO.MemoryStream
  33.         imge.Save(mem, Imaging.ImageFormat.Jpeg)
  34.         imge.Dispose()
  35.         mem.Position = 0
  36.         imge = Drawing.Image.FromStream(mem)
  37.         Clipboard.SetImage(imge)
  38.         '
  39.         '<<<ARGUMENTOS DE SAIDA
  40.         'Use RTREAL  (5001) for doubles
  41.         'Use RTSHORT (5003) for integers
  42.         'Use RTSTR   (5005) for strings
  43.         Dim rbfResult As ResultBuffer
  44.         rbfResult = New ResultBuffer( _
  45.             New TypedValue(CInt(5005), MYIMG))
  46.         Return rbfResult
  47.     End Function
  48.     <LispFunction("FIMGIMP")> _
  49.     Public Function FIMGIMP(ByVal rbfArgs As ResultBuffer) As ResultBuffer
  50.         '
  51.         '>>>ARGUMENTOS DE ENTRADA
  52.         Dim arInputArgs As Array
  53.         arInputArgs = rbfArgs.AsArray
  54.         Dim MYSTR As String = CStr(CType(arInputArgs.GetValue(0), TypedValue).Value)
  55.         Dim MYIMG As String = CStr(CType(arInputArgs.GetValue(1), TypedValue).Value)
  56.         '
  57.         Try
  58.             Dim client As New WebClient()
  59.             'By default, the google static map api returns a png file
  60.             client.DownloadFile(MYSTR, MYIMG)
  61.         Catch
  62.         End Try
  63.         '
  64.         '<<<ARGUMENTOS DE SAIDA
  65.         'Use RTREAL  (5001) for doubles
  66.         'Use RTSHORT (5003) for integers
  67.         'Use RTSTR   (5005) for strings
  68.         Dim rbfResult As ResultBuffer
  69.         rbfResult = New ResultBuffer( _
  70.             New TypedValue(CInt(5005), MYIMG))
  71.         Return rbfResult
  72.     End Function
LISP代码:
  1. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  2. (DEFUN C:IMGOLE ()
  3. (COMMAND "_UNDO" "_G")
  4. (SETQ #CAD (SUBSTR (GETVAR "ACADVER") 1 2))
  5. (COND
  6. ((= #CAD "17")(SETQ ARQUIVO "IMGOLENET3.DLL" ));ACAD 2007/2008/2009
  7. ((= #CAD "18")(SETQ ARQUIVO "IMGOLENET4.DLL" ));ACAD 2010/2011/2012
  8. ((= #CAD "19")(SETQ ARQUIVO "IMGOLENET4.DLL" ));ACAD 2013/2014
  9. ((= #CAD "20")(SETQ ARQUIVO "IMGOLENET45.DLL"));ACAD 2015/2016
  10. ((= #CAD "21")(SETQ ARQUIVO "IMGOLENET45.DLL"));ACAD 2017
  11. ((= #CAD "22")(SETQ ARQUIVO "IMGOLENET45.DLL"));ACAD 2018
  12. ((= #CAD "23")(SETQ ARQUIVO "IMGOLENET45.DLL"));ACAD 2019
  13. ( T           (SETQ ARQUIVO "IMGOLENET45.DLL"));
  14. )
  15. (VL-CMDF "NETLOAD" (FINDFILE ARQUIVO))
  16. ;
  17. (SETQ LLISTA  (SSGET "_X" (LIST (CONS 0 "IMAGE") )))
  18. (SETQ NN 0)
  19. (IF LLISTA
  20.    (PROGN
  21.    (FOREACH EEP (SSNAMEX LLISTA)
  22.       (SETQ NN  (+ NN 1))
  23.       (SETQ LL  (ENTGET (CADR EEP)))
  24.       (SETQ PT  (CDR (ASSOC 10 LL)))
  25.       (SETQ PT11 (CDR (ASSOC 11 LL)))
  26.       (SETQ PT12 (CDR (ASSOC 12 LL)))
  27.       (SETQ IMG  (CDR (ASSOC 1 (ENTGET (CDR (ASSOC 340 LL))))))
  28.       (SETQ ANGG (RPG (ANGLE (LIST 0 0) PT11)))
  29.       (SETQ ANGG (- 360.0 ANGG))
  30.       (SETQ SCX  (* 512 (DISTANCE (LIST 0 0) PT11)))
  31.       (SETQ SCY  (* 512 (DISTANCE (LIST 0 0) PT12)))
  32.       (COMMAND "_IMAGE" "_D" (VL-FILENAME-BASE IMG))
  33.       (IMGPASTE IMG PT ANGG)
  34.       (SETQ ENTO (ENTLAST))
  35.       (SETQ LISO (ENTGET ENTO))
  36.       (SETQ PT10 (CDR (ASSOC 10 LISO)))
  37.       (SETQ PT11 (CDR (ASSOC 11 LISO)))
  38.       (SETQ DXO  (- (CAR  PT11) (CAR  PT10)))
  39.       (SETQ DYO  (- (CADR PT10) (CADR PT11)))
  40.       ;
  41.       (COMMAND "_SCALE" ENTO "" PT (/ SCX DYO))
  42.       (COMMAND "_DRAWORDER" (ENTLAST) "" "_B")
  43.    )
  44.    (SETVAR "OLEFRAME" 0)
  45.    (COMMAND "_REGEN")
  46.    (ALERT (STRCAT ">> " (ITOA NN) " << IMAGES CONVERTEDS."
  47.                   "\n"
  48.                   "\nOLEFRAME (System Variable)"
  49.                   "\n= 0 Frame is not displayed and not plotted"
  50.                   "\n= 1 Frame is displayed and is plotted"
  51.                   "\n= 2 Frame is displayed but is not plotted"
  52.                   "\n"
  53.                   "\nType U to back"
  54.           )
  55.    )
  56.    )
  57.    (ALERT (STRCAT ">> " (ITOA NN) " << IMAGES NOT FOUNDS."))
  58. )
  59. (COMMAND "_UNDO" "_E")
  60. (PRINC)
  61. )
  62. ;...
  63. (defun IMGPASTE (image-path 2d-insert-point image-angg / cmdecho elast nircmd-path x y )
  64. ;;;www.theswamp.org by MP Seagull
  65.     (and
  66.         (progn (setq elast (entlast)) t)
  67.         (setq cmdecho (getvar 'cmdecho))
  68.         (setvar 'cmdecho 0)
  69.         (setq image-path (findfile image-path))
  70.         (progn
  71.             (FIMGOLE IMAGE-PATH image-angg) ;;;DLL
  72.             (command ".pasteclip" (mapcar 'set '(x y) 2d-insert-point))
  73.         )
  74.     )
  75.     (setvar 'cmdecho cmdecho)
  76.     (not (equal elast (entlast)))
  77. )
  78. ;...
  79. (DEFUN GPR  ($G) (* $G (/ PI 180)) )
  80. (DEFUN RPG  ($R) (* $R (/ 180 PI)) )
  81. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  82. (PRINC)
GMT+8, 2026-11-3 15:13 , Processed in 0.408866 second(s), 28 queries , Gzip On.
