查看: 1301|回复: 0
[每日一码] Zoom extents in all viewports
发表于 2021-1-14 23:34:25 | 显示全部楼层 |阅读模式
  1. ;;; zoome.lsp
  2. ;;;
  3. ;;; Zoom extents in all viewports
  4. ;;;
  5. ;;; By Jimmy Bergmark
  6. (defun c:zoome (/ oldcmdecho vplist curcvport nr vpss ms en x)
  7.   (setq oldcmdecho (getvar "cmdecho"))
  8.   (setvar "cmdecho" 0)
  9.   (setq vplist (mapcar 'car (vports)))
  10.   (setq curcvport (getvar "cvport"))
  11.   (if (= (getvar "tilemode") 0)
  12.     (progn
  13.       (if (= (setq ms (getvar "cvport")) 1)
  14.         (command "._mspace")
  15.       )
  16.       (setq vpss (ssget "_x"
  17.                         (list '(-4 . "<AND")
  18.                               '(0 . "VIEWPORT")
  19.                               (cons 410 (getvar "ctab"))
  20.                               '(-4 . "<NOT")
  21.                               '(69 . 1)
  22.                               '(-4 . "NOT>")
  23.                               '(-4 . "AND>")
  24.                         )
  25.                  )
  26.       )
  27.       (setq nr 0)
  28.       (if vpss                          ; in case there are no viewports
  29.         (repeat (sslength vpss)
  30.           (setq en (entget (ssname vpss nr)))
  31.           (if (and (= 0 (logand 1 (cdr (assoc 90 en))))
  32.                                         ; not perspective
  33.                    (< 0 (cdr (assoc 68 en))) ; on and active
  34.                    (/= 16384 (logand 16384 (cdr (assoc 90 en))))
  35.                                         ; not locked
  36.               )
  37.             (progn
  38.               (setvar "cvport" (cdr (assoc 69 en)))
  39.               (command "._zoom" "_e")
  40.             )
  41.           )
  42.           (setq nr (+ 1 nr))
  43.         )
  44.       )
  45.       (if (= ms 1) (command "._pspace"))
  46.     )
  47.     (foreach x vplist
  48.       (setvar "cvport" x)
  49.       (command "._zoom" "_e")
  50.     )
  51.   )
  52.   (setvar "cvport" curcvport)
  53.   (setvar "cmdecho" oldcmdecho)
  54.   (princ)
  55. )
GMT+8, 2026-11-3 15:06 , Processed in 0.570426 second(s), 29 queries , Gzip On.
