查看: 1542|回复: 0
[每日一码] 打断对象(提供4种方法)
已领礼包: 20个
发表于 2021-1-16 17:40:15 | 显示全部楼层 |阅读模式
This is a bundled function for Breaking Objects.
After writing the BreakAll function the rest was easy.
The following functions are a result.
c:BreakAll -      Break all objects selected
c:BreakwObjects - Break many objects with a single object
c:BreakObject -   Break a single object with many objects
c:BreakWith -     Break selected objects with other selected objects
c:BreakTouching - Break objects touching the single Break object
c:BreakSelected - Break selected objects with any  objects that touch it
c:MyBreak - Dialog with buttons to run three of the routines
c:BreakRemove - Break selected object with any objects that touch it & remove
                        every other new segment, start with selected object
Note: Color in picture not by lisp, but added for clairity.
文件名称:BreakObjects23.LSP
下载次数:40  文件大小:41.75 KB
下面是增加的UI界面:
DOSLIB版本:
  1. ;;; Require doslib
  2. ;;; Variable glb::BRK_des is global.
  3. (defun C:BRK (/ lstPair)
  4.   (setq        lstPair
  5.          (list (cons "Break all objects selected" "BreakAll")
  6.                (cons "Break many objects with a single object"
  7.                      "BreakwObjects"
  8.                )
  9.                (cons "Break a single object with many objects"
  10.                      "BreakObject"
  11.                )
  12.                (cons "Break a single object with many objects" "BreakWith")
  13.                (cons "Break objects touching the single Break object"
  14.                      "BreakTouching"
  15.                )
  16.                (cons "Break selected objects with any  objects that touch it"
  17.                      "BreakSelected"
  18.                )
  19.          )
  20.   )
  21.   (setq        glb::BRK_des
  22.          (apply        'dos_listbox
  23.                 (vl-remove
  24.                   nil
  25.                   (append (list        "List of commands for breaking"
  26.                                 "Select command"
  27.                                 (mapcar 'car lstPair)
  28.                           )
  29.                           (list glb::BRK_des)
  30.                   )
  31.                 )
  32.          )
  33.   )
  34.   (eval
  35.     (read (strcat "(C:" (cdr (assoc glb::BRK_des lstPair)) ")"))
  36.   )
  37.   (princ)
  38. )
XDRX API 版本:
  1. ;;; Require XDRX API
  4.   (setq        lstPair
  7.                      "BreakwObjects"
  8.                )
  10.                      "BreakObject"
  11.                )
  14.                      "BreakTouching"
  15.                )
  17.                      "BreakSelected"
  18.                )
  19.          )
  20.   )
  22.          (apply        'xdrx_ui_listbox
  23.                 (vl-remove
  24.                   nil
  28.                           )
  30.                   )
  31.                 )
  32.          )
  33.   )
  34.   (eval
  36.   )
  37.   (princ)
  38. )
GMT+8, 2026-11-4 01:49 , Processed in 0.453324 second(s), 33 queries , Gzip On.
