查看: 1403|回复: 2
[每日一码] 获取系统路径
已领礼包: 20个
发表于 2021-1-16 18:39:56 | 显示全部楼层 |阅读模式
  1. (defun _GetSpecialFolder ( int / fso fob res )
  2.     (vl-catch-all-apply
  3.        '(lambda nil
  4.             (setq fso (vlax-create-object "Scripting.FileSystemObject")
  5.                   fob (vlax-invoke-method fso 'getspecialfolder int)
  6.                   res (vlax-get-property fob 'path)
  7.             )
  8.         )
  9.     )
  10.     (if fob (vlax-release-object fob))
  11.     (if fso (vlax-release-object fso))
  12.     res
  13. )
命令: (_GETSPECIALFOLDER 1)
"C:\\Windows\\System32"
命令: (_GETSPECIALFOLDER 2)
"C:\\Users\\DSJFWZ~1\\AppData\\Local\\Temp"
目录路径详见:
Reference
Arguments
  • object
    Required. Always the name of a FileSystemObject.
  • folderspec
    Required. The name of the special folder to be returned. Can be any of the constants shown in the Settings section.
Settings
The folderspec argument can have any of the following values:
SETTINGS
Constant
Value
Description
WindowsFolder
0
The Windows folder contains files installed by the Windows operating system.
SystemFolder
1
The System folder contains libraries, fonts, and device drivers.
TemporaryFolder
2
The Temp folder is used to store temporary files. Its path is found in the TMP environment
已领礼包: 1094个
发表于 2021-1-22 06:04:10 | 显示全部楼层
获取系统路径,感谢分享!
发表于 2022-6-9 11:07:43 | 显示全部楼层
看到好贴必点赞,感谢分享!
GMT+8, 2026-11-2 21:57 , Processed in 0.470978 second(s), 33 queries , Gzip On.
