查看: 1427|回复: 1
[每日一码] 增强的NTH函数
已领礼包: 20个
发表于 2021-1-19 01:50:07 | 显示全部楼层 |阅读模式
  1. ;;  CAB  10/15/2005
  2. ;;+++++++++++++++++++++++++++++++++++++++++++++++++++++
  3. ;;  Return a sub list starting at the nth position and
  4. ;;  with the number of items specified by num
  5. ;;+++++++++++++++++++++++++++++++++++++++++++++++++++++
  6. (defun nth+ (idx ; start position 0 = first item
  7.              lst ; list of items
  8.              num ; number of items to return
  9.              ;;    0= all remaining items
  10.              / newlst)
  11.   (and (or (numberp num) ; catch non numbers
  12.            (setq num 0)) ; force all
  13.        (zerop num) ; if zero
  14.        (setq num (length lst)) ; all
  15.   )
  16.   (repeat num
  17.     (setq newlst (cons (nth idx lst) newlst)
  18.           idx (1+ idx))
  19.   )
  20.   (reverse (vl-remove nil newlst))
  21. )
  1. (defun c:tt()
  2.   (print (nth+ 0 '(1 2 3 4 5) 2)) ; |-> (1 2)
  3.   (print (nth+ 3 '(1 2 3 4 5) 2)) ; |-> (4 5)
  4.   (print (nth+ 4 '(1 2 3 4 5) 5)) ; |-> (5)
  5.   (print (nth+ 6 '(1 2 3 4 5) 2)) ; |-> nil
  6.   (print (nth+ 2 '(1 2 3 4 5) 0)) ; |-> (3 4 5)
  7.   (princ)
  8. )
评分
参与人数 1D豆 +2 收起 理由
fzhougeng + 2 好主题奖!
查看全部评分
已领礼包: 418个
发表于 2021-1-19 21:35:40 | 显示全部楼层
实用,谢谢提供。
GMT+8, 2026-11-3 19:14 , Processed in 0.457046 second(s), 32 queries , Gzip On.
