查看: 1283|回复: 0
[每日一码] 图层孤立(Layer Isolate)
发表于 2021-1-19 09:24:51 | 显示全部楼层 |阅读模式
  1. ;; Layer (un)ISOLATE
  2. ;;
  3. ;; File: laiso.lsp
  4. ;;
  5. ;;  Pseudo Code:
  6. ;;
  7. ;;  ISOLATE TOOL
  8. ;;  ------------
  9. ;;  o Select an ent(s) to isolate (leave on)
  10. ;;  o Get layers from those ents
  11. ;;  ~ Clean up list of layers by removing dups
  12. ;;  o Get layers of dwg currently on
  13. ;;  o remove list of layers to be left on
  14. ;;  o set a global variable with layer list to be turned off
  15. ;;  o if current layer is to be turned off...
  16. ;;      o switch clayer to one of those in the isolate list
  17. ;;  o itterate thru the list and turn each one off
  18. ;;
  19. (defun Select-Ent-lst ( )
  20.   (
  21.    ;; Itterate thru a Selection Set and return a list of items
  22.    ;; used to allow end user to select some items they wish to keep
  23.    (lambda (ss / lst cntr)
  24.      (if (null cntr)
  25.        (setq cntr 0) )
  26.      (if (null lst)
  27.        (setq lst '()) )
  28.       (if (eq (type ss) 'PICKSET)
  29.         (repeat (sslength ss)
  30.            (setq lst (append lst (list (entget (ssname ss cntr)))))
  31.            (setq cntr (1+ cntr)))
  32.         '*ERROR* )
  33.      lst
  34.      )
  35.     (ssget)) )
  36. (defun Build-Layer-lst ( ent-lst )
  37.   (mapcar
  38.    ;; Build a list of layers to leave on
  39.    '(lambda (x) (cdr (assoc 8 x))) ent-lst) )
  40. (defun clean-lst ( my-lst / lst )
  41. ;; Clean up a list of items; remove duplicates
  42.      (foreach x my-lst
  43.        (if (not (member x lst))
  44.          (setq lst (cons x lst))))
  45.      (reverse lst)
  46. )
  47. (defun Drawing-Layers-lst ( / )
  48.   ;; create a list of layers in the drawing.
  49.   ;; minus the ones turned off or frozen.
  50.   (while (setq x (tblnext "LAYER" (not x)))
  51.          (if (not (or (= (cdr (assoc 70 x)) 1) (< (cdr (assoc 62 x)) 0)))
  52.            (setq mlst (append mlst (list (cdr (cadr x)))))
  53.            )
  54.          )
  55.   mlst
  56.   )
  57. (defun rip-n-flip (lm lc / l-m cntr)
  58.   (setq cntr (length lc) l-m (mapcar 'list lm))
  59.   (while (> cntr -1)
  60.     (setq l-m (subst nil (list (nth cntr lc)) l-m))
  61.     (setq cntr (1- cntr))
  62.     (apply 'append l-m)) )
  63. (defun Lay (mode lst / layer)
  64.   (foreach x lst
  65.            (setq layer (entget (tblobjname "LAYER" x)))
  66.            (cond
  67.                ((and (null mode) (not (minusp (cdr (assoc 62 layer)))))
  68.                   (setq layer (subst (cons 62 (1+ (~ (cdr (assoc 62 layer))))) (assoc 62 layer) layer)))
  69.               ((and mode  (minusp (cdr (assoc 62 layer))))
  70.                  (setq layer (subst (cons 62 (abs (cdr (assoc 62 layer)))) (assoc 62 layer) layer)))
  71.               )
  72.            (entmod layer)
  73.            )
  74.   (princ) )
  75. ;;;===================================================================;
  76. ;;; main procedures section                                           ;
  77. ;;;===================================================================;
  78. (defun c:laiso ( / ToIsolate-Layer-List)
  79.   ;; (c:laiso)
  80.   (setq ToIsolate-Layer-List
  81.         (clean-lst
  82.           (Build-Layer-lst
  83.             (Select-Ent-lst))) )
  84.   (setq
  85.     *Layoff-layer-list*
  86.     (rip-n-flip
  87.       (Drawing-Layers-lst)
  88.       ToIsolate-Layer-List))
  89.   (if (member (getvar 'CLAYER) *Layoff-layer-list*)
  90.     (progn
  91.       (princ "\nCurrent layer scheduled to be turned off, switching layer...")
  92.       (setvar 'clayer (car ToIsolate-Layer-List))) )
  93.   (lay nil *Layoff-layer-list*) )
  94. (defun c:laon ( )
  95.   ;; (c:laon)
  96.   (if *Layoff-layer-list*
  97.     (progn
  98.       (lay "on" *Layoff-layer-list*)
  99.       (setq *Layoff-layer-list* nil))
  100.     '*ERROR*:NoList)
  101.   (princ) )
GMT+8, 2026-11-3 20:48 , Processed in 0.529289 second(s), 29 queries , Gzip On.
