查看: 1987|回复: 1
[每日一码] 将选定的Text / MText对象翻转180°
发表于 2021-1-19 10:38:19 | 显示全部楼层 |阅读模式
将选定的Text / MText对象翻转180°(基点是对象边界框的中点)
  1. (defun c:TFlip (/ ss)
  2.   ;; Flip selected Text/MText objects 180° (basepoint is midpoint of object bounding box)
  3.   ;; Required subroutines: AT:BoundingBoxMidPoint
  4.   ;; Alan J. Thompson, 07.13.10
  5.   (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT"))))
  6.     (progn
  7.       (vlax-for        x (setq
  8.                     ss (vla-get-activeselectionset
  9.                          (cond (*AcadDoc*)
  10.                                ((setq *AcadDoc*        (vla-get-activedocument
  11.                                                   (vlax-get-acad-object)
  12.                                                 )
  13.                                 )
  14.                                )
  15.                          )
  16.                        )
  17.                   )
  18.         (vla-rotate x (vlax-3d-point (AT:BoundingBoxMidPoint x)) pi)
  19.       )
  20.       (vla-delete ss)
  21.     )
  22.   )
  23.   (princ)
  24. )
  25. (defun AT:BoundingBoxMidPoint (obj / a b)
  26.   ;; Return midpoint between boundingbox of specified VLA-OBJECT
  27.   ;; Alan J. Thompson, 07.13.10
  28.   (if (eq (type obj) 'VLA-OBJECT)
  29.     (progn
  30.       (vla-getboundingbox obj 'a 'b)
  31.       (apply (function
  32.                (lambda (p1 p2)
  33.                  (mapcar (function (lambda (a b) (/ (+ a b) 2.))) p1 p2)
  34.                )
  35.              )
  36.              (mapcar (function vlax-safearray->list) (list a b))
  37.       )
  38.     )
  39.   )
  40. )
已领礼包: 228个
发表于 2021-1-19 14:03:18 | 显示全部楼层
谢谢分享!!!!
GMT+8, 2026-11-3 20:01 , Processed in 0.510875 second(s), 31 queries , Gzip On.
