查看: 2060|回复: 6
[每日一码] 获得选择集的包围框
已领礼包: 20个
发表于 2021-1-20 04:51:24 | 显示全部楼层 |阅读模式
  1. (defun SSBoundingBox ( ss / _GetBoundingBox _SStoObjects _Main )
  2.     (defun _GetBoundingBox ( object / p1 p2 )
  3.         (vl-catch-all-apply
  4.            '(lambda ()
  5.                 (vlax-invoke-method
  6.                     object
  7.                    'GetBoundingBox
  8.                    'p1
  9.                    'p2
  10.                 )
  11.             )
  12.         )
  13.         (if p1
  14.             (   (lambda (data)
  15.                     (mapcar
  16.                        '(lambda (funcs)
  17.                             (mapcar
  18.                                '(lambda (func)
  19.                                     (apply func data)
  20.                                 )
  21.                                 funcs
  22.                             )
  23.                         )
  24.                        '(   (caar cadar)
  25.                             (caadr cadar)
  26.                             (caadr cadadr)
  27.                             (caar cadadr)
  28.                         )
  29.                     )
  30.                 )
  31.                 (list
  32.                     (mapcar
  33.                         'vlax-safearray->list
  34.                         (list p1 p2)
  35.                     )
  36.                 )
  37.             )
  38.         )
  39.     )
  40.
  41.     (defun _SStoObjects ( ss / i objects )
  42.         (if (eq 'pickset (type ss))
  43.             (repeat (setq i (sslength ss))
  44.                 (setq objects
  45.                     (cons
  46.                         (vlax-ename->vla-object
  47.                             (ssname ss
  48.                                 (setq i (1- i))
  49.                             )
  50.                         )
  51.                         objects
  52.                     )
  53.                 )
  54.             )
  55.         )
  56.         objects
  57.     )
  58.
  59.     (defun _Main ( ss / boundingboxes )
  60.         (cond
  61.             (   (setq boundingboxes
  62.                     (vl-remove-if 'null
  63.                         (mapcar '_GetBoundingBox
  64.                             (_SStoObjects ss)
  65.                         )
  66.                     )
  67.                 )
  68.                 (mapcar
  69.                    '(lambda ( func pair / lst )
  70.                         (list
  71.                             (apply (car pair)
  72.                                 (mapcar 'car
  73.                                     (setq lst
  74.                                         (mapcar
  75.                                             func
  76.                                             boundingboxes
  77.                                         )
  78.                                     )
  79.                                 )
  80.                             )
  81.                             (apply (cadr pair)
  82.                                 (mapcar 'cadr lst)
  83.                             )
  84.                         )
  85.                     )
  86.                    '(car cadr caddr cadddr)
  87.                    '((min min)(max min)(max max)(min max))
  88.                 )
  89.             )
  90.         )
  91.     )
  92.
  93.     (_Main ss)
  94.
  95. )
发表于 2021-1-20 07:44:46 | 显示全部楼层
express tools 提供的函数:
(ACET-GEOM-SS-EXTENTS (ssget) 0.01)
(ACET-GEOM-SS-EXTENTS-ACCURATE(ssget))
(ACET-GEOM-SS-EXTENTS-FAST(ssget))
XDRX API:
(xdrx-entity-box ss)
已领礼包: 756个
发表于 2021-1-20 09:36:25 | 显示全部楼层
两位牛人。
我理解是获取x,y最小值和最大值,这样就获得了包围选择集的框
已领礼包: 2230个
发表于 2021-1-20 10:50:15 | 显示全部楼层
做个对论坛有益的人。
已领礼包: 604个
发表于 2021-1-20 11:56:28 | 显示全部楼层
综合一下,有ET就用ET的,没有就用M的
  1. (defun _MyBoxs (ss)
  2.   (if ACET-GEOM-SS-EXTENTS-ACCURATE
  3.     (ACET-GEOM-SS-EXTENTS-ACCURATE SS)
  4.     (SSBoundingBox ss)
  5.   )
  6. )
发表于 2021-1-21 10:45:42 | 显示全部楼层
跟大神学习学习!
发表于 2022-6-9 09:33:30 | 显示全部楼层
看到好贴必点赞,感谢分享!
GMT+8, 2026-11-4 01:26 , Processed in 0.438081 second(s), 41 queries , Gzip On.
