查看: 1401|回复: 1
[每日一码] 增强的线型加载代码
发表于 2021-1-20 15:57:13 | 显示全部楼层 |阅读模式
  1. (defun lt_load (ltname / StrBrk        DCTAG F        FILES FLAG FN L        LLST LST NL PATH
  2.                 TFILE TMP)
  3.   ;; String Breaker by Lee McDonnell
  4.   (defun StrBrk        (str chrc / pos lst)
  5.     (while (setq pos (vl-string-position chrc str))
  6.       (setq lst        (cons (substr str 1 pos) lst)
  7.             str        (substr str (+ pos 2))
  8.       )
  9.     )
  10.     (reverse (cons str lst))
  11.   )
  12.   (foreach Path        (vl-remove "" (StrBrk (getenv "ACAD") 59))
  13.     (and (setq files (vl-directory-files Path "*.lin" 1))
  14.          (setq lst
  15.                 (append        lst
  16.                         (mapcar        (function (lambda (x) (strcat Path "\\" x)))
  17.                                 files
  18.                         )
  19.                 )
  20.          )
  21.     )
  22.   )
  23.   (foreach file        lst
  24.     (setq tmp (open file "r"))
  25.     (while (setq nl (read-line tmp))
  26.       (and (eq "*" (substr nl 1 1))
  27.            (eq (strcase ltname)
  28.                (setq l (strcase (car (StrBrk (substr nl 2) 44))))
  29.            )
  30.            (setq
  31.              llst (cons        (cons l (strcat (vl-filename-base file) ".lin"))
  32.                         llst
  33.                   )
  34.            )
  35.       )
  36.     )
  37.     (close tmp)
  38.   )
  39.   (if lLst
  40.     (if        (< 1 (length lLst))
  41.       (progn
  42.         (setq
  43.           fn (open (setq tfile (vl-filename-mktemp "" "" ".dcl")) "w")
  44.         )
  45.         (foreach str
  46.                  '("lt_dcl : dialog { label = \"Select Load File\"; spacer;"
  47.                    ": popup_list { alignment = centered; key = \"flin\"; } spacer; ok_cancel; } "
  48.                   )
  49.           (write-line str fn)
  50.         )
  51.         (close fn)
  52.         (if (and (<= 0 (setq dcTag (load_dialog tFile)))
  53.                  (new_dialog "lt_dcl" dcTag)
  54.             )
  55.           (progn
  56.             (start_list "flin")
  57.             (mapcar 'add_list (mapcar 'cdr lLst))
  58.             (end_list)
  59.             (setq f (car lLst))
  60.             (action_tile "flin" "(setq f (nth (atoi $value) lLst))")
  61.             (action_tile "accept" "(done_dialog 1)")
  62.             (action_tile "cancel" "(done_dialog 0)")
  63.             (setq flag (start_dialog))
  64.             (unload_dialog dcTag)
  65.           )
  66.         )
  67.         (vl-file-delete tfile)
  68.       )
  69.       (setq flag 1
  70.             f         (car lLst)
  71.       )
  72.     )
  73.   )
  74.   (if (eq flag 1)
  75.     (vla-load
  76.       (vla-get-linetypes
  77.         (vla-get-ActiveDocument
  78.           (vlax-get-acad-object)
  79.         )
  80.       )
  81.       (car f)
  82.       (cdr f)
  83.     )
  84.   )
  85.   (and (tblsearch "LTYPE" ltname))
  86. )
发表于 2021-1-21 10:36:15 | 显示全部楼层
跟大神学习学习!
GMT+8, 2026-11-4 01:49 , Processed in 0.418998 second(s), 34 queries , Gzip On.
