查看: 1648|回复: 1
[每日一码] 锁定指定图层和解锁所有图层(ActiveX)
发表于 2021-1-20 18:22:49 | 显示全部楼层 |阅读模式
  1. ;; Unlock locked layers.
  2.   ;; Argument: document object.
  3.   ;; Returns a list of layer objects which were locked,
  4.   ;; or nil if none are locked.
  5.   ;; Typically the function filters out xref layers,
  6.   ;; but not in this case.
  7.   (defun MD:UnlockLayers (doc / laylst)
  8.     (vlax-for x (vla-get-Layers doc)
  9.       (if (eq :vlax-true (vla-get-lock x))
  10.         (progn
  11.           (setq laylst (cons x laylst))
  12.           (vla-put-lock x :vlax-false)
  13.         )
  14.       )
  15.     )
  16.     laylst
  17.   ) ;end
  18.   ;; Argument: a list of layer objects from UnlockLayers above.
  19.   ;; Use vl-catch-all-apply in case a locked
  20.   ;; layer was deleted in the calling function.
  21.   (defun MD:RelockLayers (lst)
  22.     (foreach x lst
  23.       (vl-catch-all-apply 'vla-put-lock (list x :vlax-true))
  24.     )
  25.   ) ;end
发表于 2021-1-21 09:57:27 | 显示全部楼层
跟大神学习学习!
GMT+8, 2026-11-3 20:02 , Processed in 0.377567 second(s), 31 queries , Gzip On.
