查看: 1965|回复: 5
[每日一码] 更新图中所有的INSERT
发表于 2021-1-21 08:10:00 | 显示全部楼层 |阅读模式
  1. ;;;  ----------- Update Blocks - Version 1.0 -----------
  2. ;;;  Copyright (C) 2008  by ResourceCAD International
  3. ;;;  Author:  K.E. Blackie
  4. ;;;
  5. ;;;
  6. ;;;  RESOURCECAD INTERNATIONAL PROVIDES THIS PROGRAM "AS IS" AND WITH
  7. ;;;  ALL FAULTS. RESOURCECAD INTERNATIONAL SPECIFICALLY DISCLAIMS ANY
  8. ;;;  IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR
  9. ;;;  USE.  RESOURCECAD INTERNATIONAL DOES NOT WARRANT THAT THE OPERATION
  10. ;;;  OF THE PROGRAM WILL BE UNINTERRUPTED OR ERROR FREE.
  11. ;;;
  12. ;;;
  13. ;;;  ResouceCAD International
  14. ;;;  http://www.resourcecad.com
  15. ;;;
  16. ;;;  DESCRIPTION
  17. ;;;  BLUPD will refresh each block reference in the drawing by finding
  18. ;;;  the drawing file in the support path. If the file is not found
  19. ;;;  the block is skipped
  20. ;;;
  21. ;;;  May 9, 2008        Initial Release
  22. ;;;
  23. ;;;  ------------------------------------------------------------
  24. (defun c:blupd ( / cmdecho regen n bpath)
  25.   (setq cmdecho (getvar "cmdecho"))
  26.   (setq regen (getvar "regenmode"))
  27.   (setvar "cmdecho" 0)
  28.   (setvar "regenmode" 0)
  29.   (foreach n (blocklist)
  30.     (setq bpath (findfile (strcat n ".dwg")))
  31.     (if bpath
  32.       (vl-cmdf "insert" (strcat n "=" bpath) "y" )
  33.     )
  34.     (command)
  35.   )
  36.   (setvar "cmdecho" cmdecho)
  37.   (setvar "regenmode" regen)
  38.   (princ)
  39. )
  40. (defun blocklist( / bl ndx bname blist bname bnlist)
  41.   (setq bl (ssget "x" '((0 . "insert")))
  42.         ndx 0)
  43.   (repeat (sslength bl)
  44.     (setq bname (ssname bl ndx)
  45.           blist (entget bname)
  46.           bname (cdr (assoc 2 blist))
  47.           ndx (1+ ndx)
  48.     )
  49.     (if (=(member bname bnlist)nil)
  50.       (setq bnlist (append bnlist (list bname)))
  51.     )
  52.   )
  53.   bnlist
  54. )
已领礼包: 375个
发表于 2021-1-21 09:51:13 | 显示全部楼层
楼主,是属性块,可以吗??
已领礼包: 20个
发表于 2021-1-21 10:00:42 | 显示全部楼层
SHUNDocker 发表于 2021-1-21 09:51
楼主,是属性块,可以吗??
只要是图块,外部DWG,你有改变的话,用这个更新你当前图
你说的属性块,有什么要求想实现什么?
已领礼包: 756个
发表于 2021-1-21 10:02:39 | 显示全部楼层
学习了,谢谢分享
已领礼包: 375个
发表于 2021-1-22 09:20:40 | 显示全部楼层
为啥输入后lupd是未知命令?显示“错误: 无法重定义外部参照或其依赖。”
发表于 2021-3-22 23:39:08 | 显示全部楼层
楼主,是属性块,可以吗??
GMT+8, 2026-11-4 08:17 , Processed in 0.474650 second(s), 38 queries , Gzip On.
