查看: 1486|回复: 1
[每日一码] 基于两点的多重拷贝
发表于 2021-1-28 11:26:40 | 显示全部楼层 |阅读模式
  1. (defun c:mcopy
  2.   (/ mcopy_err AcDoc Space pt1 pt2 nb)
  3.   (vl-load-com)
  4.   (defun mcopy_err (msg)
  5.     (if        (= msg "Function canceled")
  6.       (princ)
  7.       (princ (strcat "\ nError:" msg))
  8.     )
  9.     (vla-endUndoMark AcDoc)
  10.     (setq *error*   m:err
  11.               m:err nil
  12.     )
  13.     (princ)
  14.   )
  15.   (setq        AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
  16.         Space (if (= (getvar "CVPORT") 1)
  17.                 (vla-get-PaperSpace AcDoc)
  18.                 (vla-get-ModelSpace AcDoc)
  19.               )
  20.   )
  21.   (vla-StartUndoMark AcDoc)
  22.   (if (and (= 1 (getvar "pickfirst"))
  23.            (setq ss (cadr (ssgetfirst)))
  24.       )
  25.     (sssetfirst nil nil)
  26.     (setq ss (ssget))
  27.   )
  28.   (initget 1)
  29.   (setq pt1 (getpoint "\ nSpecify offset, first point:"))
  30.   (initget 1)
  31.   (setq pt2 (getpoint pt1 "\ nSecond point:"))
  32.   (initget 1)
  33.   (setq nb (getint "\ nNumber of elements:"))
  34.   (foreach obj (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  35.     (setq obj (vlax-ename-> vla-object obj))
  36.     (repeat (1- nb)
  37.       (vla-Copy obj)
  38.       (vla-move        obj
  39.                 (vlax-3d-point (trans pt1 1 0))
  40.                 (vlax-3d-point (trans pt2 1 0))
  41.       )
  42.     )
  43.   )
  44.   (vla-endUndoMark AcDoc)
  45.   (setq        *error*  m:err
  46.             m:err nil
  47.   )
  48.   (princ)
  49. )
已领礼包: 6881个
发表于 2021-1-28 16:08:46 | 显示全部楼层
谢谢
请教有没有倾斜阵列的
GMT+8, 2026-11-4 17:51 , Processed in 0.561731 second(s), 31 queries , Gzip On.
