查看: 1321|回复: 3
[求助] CAD统计字符长度控制
发表于 2021-1-28 15:56:01 | 显示全部楼层 |阅读模式
网上下载了一个统计图块tjtk,统计单行文字tjzf.lsp    命令tjzf 能实现文字数量以表格的方式的统计,如何在程序选择的时候 判断单行或多行文字,字符大于4,小于50的的字符,的才统计呢?
;统计块数量的源码
(defun c:tjtk(/ en mpl ss n nn m xx pt0 mpl_new i)
        (if *table-zg (princ)(setq *table-zg (* 3 (getvar "DIMSCALE"))));设置模式全局变量,初始默认值=1
        (setq ss (ssget '((0 . "INSERT"))))
        (or ss (setq ss (ssadd)))
        (setq n 0 nn (sslength ss) mpl '())
        (while (< n nn)
                (setq en (ssname ss n) data (entget en))
                (setq n (1+ n))
                (setq name (cdr (assoc 2 data)));;;
                (setq xx (assoc name mpl))
                (if xx
                        (setq m (cadr xx) m (1+ m) mpl (subst (list name m) xx mpl))
                        (setq mpl (append (list (list name 1)) mpl))
        (if mpl
                (progn
                        (setq i 0)
                        (setq mpl_new '())
                        (foreach x mpl
                                (setq mpl_new (append (list(cons (setq i (1+ i)) x)) mpl_new))
                        (setq mpl_new (append (list (list "序号" "图块名称" "数量")) (reverse mpl_new)))
                        (initget 0 "S")
                        (if (/= (setq pt0 (getpoint (strcat "\n点取表格插入点[设置(S)表格文字高度],当前文字高度:" (rtos *table-zg)))) nil)
                                (progn
                                        (while (= pt0 "S")
                                                (setq str (strcat "\n(建议高度:"(rtos (* 3 (getvar "DIMSCALE"))) ")" "  请输表格文字高度:"  "<" (rtos *table-zg) ">"))
                                                (if (setq temp (getint str))(setq *table-zg temp));采用新输入值
                                                (initget 0 "S")
                                                (if (null pt0)(exit))
                                        (if (and pt0 *table-zg)
                                                (TableLst2Table mpl_new pt0 *table-zg)
                        (princ "/nNothing!")
                (princ)
(defun c:tjzf(/ en mpl ss n nn m xx pt0 mpl_new i)
        (setq ss (ssget '((0 . "text"))))
        (while (< n nn)
                (setq n (1+ n))
                (setq name (cdr (assoc 1 data)));;;
                (if xx
                        ;(setq m (cdr xx) m (1+ m) mpl (subst (cons name m) xx mpl))
                        ;(setq mpl (cons (cons name 1) mpl))
        (if mpl
                (progn
                        (setq i 0)
                        (setq mpl_new '())
                        (foreach x mpl
                        (setq mpl_new (append (list (list "序号" "内容" "数量")) (reverse mpl_new)))
                        (initget 0 "S")
                                (progn
                                        (while (= pt0 "S")
                                                (setq str (strcat "\n(建议高度:"(rtos (* 12 (getvar "DIMSCALE"))) ")" "  请输表格文字高度:"  "<" (rtos *table-zg) ">"))
                                                (initget 0 "S")
                (princ)
;参数:
;lis --- 表格型list
;pt --- 表格左上角(点)
;zg ---- 字高(数值型)
;测试(TableLst2Table '((1 12 123 1234 12345 123456 1234567 12345678 123456780 1234567890)(1.0 0.0 0.0)(100.0 12345.0 "5551000" "1234")) (getpoint) 10)
(defun TableLst2Table (lis pt zg / emkLine emkText h len1 len2 i h1 w2 tab_h len j w1 w2 wlst p0 p1 txt)
  (defun emkLine (p1 p2)
    (entmake (list '(0 . "LINE") (cons 8 "DM_文字表格") (cons 10 p1) (cons 11 p2)))
  (defun emkText (pt str h)
    (entmake (list '(0 . "TEXT") (cons 1 str) (cons 8 "DM_文字表格") (cons 10 pt) (cons 40 h) (cons 11 pt) (cons 72 1) (cons 73 2)))
  (setq h (* zg 2)                             ; 表格高
                len1 (length lis)                      ; 表格行数len1
                len2 (apply 'max (mapcar 'length lis)) ; 表格列数len2
                p0 (list (car pt) (- (cadr pt) (* 0.5 h))); 定义文字原点
  (setq lis (mapcar '(lambda (y) (mapcar 'vl-princ-to-string y)) lis)) ; 将表中元素全部变为文本型
  ; 以下获取列宽表 wlst
  (setq i 0 w2 0 wlst '())
  (repeat len2
    (foreach e lis
      (setq txt (nth i e))
      (if (not txt) (setq txt ""))         ;如果没有字符
      (setq w1 (* (+ (strlen txt) 1) zg))  ; 列宽=(文字长度+1)*zg
      (if (> w1 w2) (setq w2 w1))          ;取最大列宽
    (setq wlst (cons w2 wlst) w2 0 i (1+ i))
  ;以下按行写出文字
  (setq wlst (reverse wlst))
  (setq i 0 j 0 w1 0 w2 0)
  (foreach e lis
    (setq h1 (- (cadr p0) (* i h)))        ; 文字行的y坐标值
    (foreach f e
      (setq w1 (nth j wlst) w2 (+ w2 w1))
      (setq p1 (list (- (+ (car p0) w2) (* w1 0.5)) h1)) ; 文字插入点
      (emkText P1 f zg)
      (setq j (1+ j))
    (setq i (1+ i) j 0 w1 0 w2 0)
  ; 开始绘制竖线
  (setq tab_h (* len1 h))                  ; 竖线长
  (emkLine pt (polar pt (* pi 1.5) tab_h)) ; 绘制左侧第一根竖线
  (setq len 0)
  (foreach x wlst                          ; 绘制竖线
    (setq len (+ x len) p1 (polar pt 0 len))
    (emkLine p1 (polar p1 (* Pi 1.5) tab_h))
  ; 开始绘制横线
  (setq i 0 len 0)
  (setq len (apply '+ wlst))              ; 横线长度
  (repeat (1+ len1)                       ; 绘制横线
    (setq p1 (polar pt (* Pi 1.5) (* i h)) i (1+ i))
    (emkLine p1 (polar p1 0 len))
  (princ)
发表于 2021-1-29 00:47:04 | 显示全部楼层
取出字符串后,
判断
(if (and (> (strlen name) 4)
           (<= (strlen name) 50))
   (progn
       ......;满足条件,这里处理
 楼主| 发表于 2021-1-29 15:33:38 | 显示全部楼层
谢谢~刚接触
 楼主| 发表于 2021-1-29 15:36:22 | 显示全部楼层
Lisphk 发表于 2021-1-29 00:47
取出字符串后,
判断
这段代码 应放在哪里呢  代码叫的  name  对应哪个变量? 刚接触,看不懂代码,谢谢了
GMT+8, 2026-11-4 07:24 , Processed in 0.419538 second(s), 34 queries , Gzip On.
