查看: 2714|回复: 0
[每日一码] SQLite数据库函数应用(一)对表任一列为索引排升(降)序
发表于 2021-1-29 00:34:22 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (defun chkerr        (cmd)
  3.     (if        (not cmd)
  4.       (progn
  5.         (princ (xdrx-sqlite-lasterr))
  6.         nil
  7.       )
  8.       t
  9.     )
  10.   )
  11.   (setq lst nil)
  12.   (repeat 10
  13.     (setq r   (xdrx-math-rand 0 255)
  14.           r1  (xdrx-math-rand 1.0 255.0)
  15.           s   (xdrx-string-rand 3)
  16.           lst (cons (list r s r1) lst)
  17.     )
  18.   )
  19.   (xdrx-prompt "lst=" (vl-prin1-to-string lst))
  20.   (setq db "d:\\test.db")
  21.   (if (findfile db)
  22.     (xdrx-file-delete db)
  23.   )
  24.   (chkerr (xdrx-sqlite-open db))
  25.   (chkerr
  26.     (xdrx-sqlite-dml
  27.       db
  28.       "create table mytable (num int, string char(64),float real);"
  29.     )
  30.   )
  31.   (setq i 0)
  32.   (mapcar '(lambda (x)
  33.              (chkerr (xdrx-sqlite-dml
  34.                        db
  35.                        (setq lxd (strcat "insert into mytable values ("
  36.                                          (itoa (car x))
  37.                                          ",'"
  38.                                          (cadr x)
  39.                                          "',"
  40.                                          (rtos (last x) 2 2)
  41.                                          ");"
  42.                                  )
  43.                        )
  44.                      )
  45.              )
  46.            )
  47.           lst
  48.   )
  49.   (setq        lst1 (xdrx-sqlite-query
  50.                db
  51.                "select * from mytable order by string;"
  52.              )
  53.   )
  54.   (xdrx-prompt "\nlst1=" (vl-prin1-to-string (cdr lst1)))
  55.    (setq        lst2 (xdrx-sqlite-query
  56.                db
  57.                "select * from mytable order by float desc;"
  58.              )
  59.   )
  60.   (xdrx-prompt "\nlst2=" (vl-prin1-to-string (cdr lst2)))
  61.   (chkerr (xdrx-sqlite-close db))
  62.   (princ)
  63. )
原随机表:
lst=
((99 "DTU" 118.605) (148 "AVB" 250.888) (118 "15A" 6.60631) (181 "63Q" 4.60972) (205 "QUK" 65.0506) (221 "F7X" 84.9369) (15 "E6H" 56.9618) (241 "PBW" 196.656) (227 "ZU7" 208.845) (170 "9L0" 160.584))
对第二列字符串排升序
SQL查询语句:"select * from mytable order by string;"
lst1=
((118 "15A" 6.61) (181 "63Q" 4.61) (170 "9L0" 160.58) (148 "AVB" 250.89) (99 "DTU" 118.6) (15 "E6H" 56.96) (221 "F7X" 84.94) (241 "PBW" 196.66) (205 "QUK" 65.05) (227 "ZU7" 208.85))
对第三列浮点数排降序
SQL查询语句: "select * from mytable order by float desc;"
lst2=
((148 "AVB" 250.89) (227 "ZU7" 208.85) (241 "PBW" 196.66) (170 "9L0" 160.58) (99 "DTU" 118.6) (221 "F7X" 84.94) (205 "QUK" 65.05) (15 "E6H" 56.96) (118 "15A" 6.61) (181 "63Q" 4.61))
GMT+8, 2026-11-22 08:55 , Processed in 0.733601 second(s), 9 queries , Gzip On, File On.
