查看: 1375|回复: 1
[每日一码] 获取MAC地址
已领礼包: 20个
发表于 2021-1-29 01:42:02 | 显示全部楼层 |阅读模式
  1. ;;Test OK with XP
  2. ;;Use WMI to Get Networkadapter MAC.
  3. ;;Author :  eachy [eachy@xdcad.net]
  4. ;;Web    :  http://www.xdcad.net
  5. ;;2005.11.22(xdl-MACAddress)
  6. (defun xdl-MACAddress (/ mac WMIobj con lox sn)
  7.   (if (setq WMIobj (vlax-create-object "wbemScripting.SwbemLocator"))
  8.     (progn
  9.       (setq
  10.         con (vl-catch-all-apply
  11.               'vlax-invoke
  12.               (list WMIobj 'ConnectServer "." "" "" "" "" "" 128 nil)
  13.             )
  14.       )
  15.       (if (vl-catch-all-error-p con)
  16.         (setq
  17.           con (vlax-invoke WMIobj 'ConnectServer "." "" "" "" "" "")
  18.         )
  19.       )
  20.       (setq lox        (vlax-invoke
  21.                   con
  22.                   'ExecQuery
  23.                   "Select * From Win32_NetworkAdapter"
  24.                 )
  25.       )
  26.       (vlax-for        item lox
  27.         (if (vlax-get item 'NetConnectionID)
  28.           (progn
  29.             (setq sn (vlax-get item 'MACAddress))
  30.             (or
  31.               (member sn mac)
  32.               (setq mac (cons sn mac))
  33.             )
  34.           )
  35.         )
  36.       )
  37.       (mapcar 'vlax-release-object
  38.               (list lox con WMIobj)
  39.       )
  40.     )
  41.   )
  42.   (reverse mac)
  43. )
命令: (XDL-MACADDRESS)
("48:4D:7E:F3:3C:1A" "48:4D:7E:F3:3C:29" "00:FF:6F:1F:E7:54" "F0:1E:34:14:FF:53" "00:50:56:C0:00:01" "00:50:56:C0:00:08" "00:FF:CA:D1:AB:4C" nil "20:0D:B0:41:98:E0")
评分
参与人数 1D豆 +5 收起 理由
hh_lj007 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2021-1-29 11:48:42 | 显示全部楼层
为什么会有nil的呢
GMT+8, 2026-11-4 17:51 , Processed in 0.407896 second(s), 31 queries , Gzip On.
