查看: 1753|回复: 3
[每日一码] 遍历所有图层,将线型设置为CONTINUOUS
发表于 2021-1-30 02:33:13 | 显示全部楼层 |阅读模式
命令版本:
  1. (defun c:l2c ( / doc)
  2.   (vl-load-com)
  3.   (vlax-for lyr (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  4.     (vlax-put lyr 'linetype "CONTINUOUS")
  5.   )
  6.   (vlax-invoke doc 'regen acallviewports)
  7.   (princ)
  8. )
函数版本:
  1. (defun rh:l2c ( lst / doc)
  2.   (setq lst (mapcar 'strcase lst))
  4.     (if (vl-position (strcase (vlax-get lyr 'name)) lst) (vlax-put lyr 'linetype "CONTINUOUS"))
  5.   )
  7. )
已领礼包: 228个
发表于 2021-1-30 09:13:47 | 显示全部楼层
谢谢的!!!!
已领礼包: 4365个
发表于 2021-1-31 01:03:26 | 显示全部楼层
已领礼包: 1094个
发表于 2021-2-2 00:06:01 | 显示全部楼层
遍历所有图层,将线型设置为CONTINUOUS。感谢分享!
GMT+8, 2026-11-4 17:26 , Processed in 0.580756 second(s), 35 queries , Gzip On.
