查看: 4427|回复: 1
通过代码实现启动表格对象的breaks
发表于 2021-1-31 01:02:29 | 显示全部楼层 |阅读模式
Enabling Table breaks through code
问题:
I would like to enable table breaks just the way AutoCAD does when clicking on the small triangular grip. Can you provide a sample code for this ?
解答:
There are properties and methods that help in configuring the table breaks. The sample code provided here may require changes to suit your needs. Here is a sample code :
  1.             Document activeDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  2.             Database db = activeDoc.Database;
  3.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  4.             PromptEntityOptions peo = new PromptEntityOptions("Select a table : ");
  5.             peo.SetRejectMessage("Please select the table to modify");
  6.             peo.AddAllowedClass(typeof(Table), true);
  7.             PromptEntityResult per = ed.GetEntity(peo);
  8.             if (per.Status != PromptStatus.OK)
  9.                 return;
  10.             ObjectId oid = per.ObjectId;
  11.             try
  12.             {
  13.                 using (Transaction tr = db.TransactionManager.StartTransaction())
  14.                 {
  15.                     Table table = tr.GetObject(oid, OpenMode.ForWrite) as Table;
  16.                     table.BreakOptions = TableBreakOptions.EnableBreaking & TableBreakOptions.RepeatTopLabels;
  17.                     table.BreakFlowDirection = TableBreakFlowDirection.Right;
  18.                     table.BreakEnabled = true;
  19.                     table.FlowDirection = FlowDirection.LeftToRight;
  20.                     table.SetBreakHeight(0, table.Height / 3.0);
  21.                     table.SetBreakOffset(0, Vector3d.XAxis * 2.0);
  22.                     table.SetBreakSpacing(25);
  23.                     table.RecomputeTableBlock(true);
  24.                     tr.Commit();
  25.                 }
  26.             }
  27.             catch (System.Exception ex)
  28.             {
  29.                 ed.WriteMessage(ex.Message);
  30.             }
发表于 2021-1-31 10:27:44 | 显示全部楼层
做个对论坛有益的人。
GMT+8, 2026-11-22 07:21 , Processed in 0.295981 second(s), 6 queries , Gzip On, File On.
