查看: 2637|回复: 4
[每日一码] lisp+c#混合编程之--C#调用lisp函数(源码)
发表于 2021-2-1 15:55:19 | 显示全部楼层 |阅读模式
复制代码
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5. namespace ClassLibrary1
  6. {
  7.     public class Class1
  8.     {
  9.         [CommandMethod("Test1", CommandFlags.Session)]
  10.         static public void Test1()
  11.         {
  12.             ResultBuffer pa = new ResultBuffer(); //lisp参数
  13.             ResultBuffer rb = new ResultBuffer(); //lisp返回值
  14.             pa.Add(new TypedValue((int)LispDataType.Text, "c:lisp1")); //lisp函数名字
  15.             pa.Add(new TypedValue((int)LispDataType.Double, 123));  //lisp参数1 Double类型也可直接用5001代码
  16.             //pa.Add(new TypedValue(5001, 123)); //也可直接用5001代码
  17.             rb = Application.Invoke(pa); //调用lisp函数,并取得返回值
  18.             if (rb != null)
  19.             {
  20.                 Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  21.                 TypedValue[] Array = rb.AsArray(); //返回值为数组
  22.                 string str = Array[0].Value.ToString();
  23.                 ed.WriteMessage("lisp返回值为:" + str);
  24.             }
  25.             //lisp参数类型及代码
  26.             //None = 5000,
  27.             //Double = 5001,
  28.             //Point2d = 5002,
  29.             //Int16 = 5003,
  30.             //Angle = 5004,
  31.             //Text = 5005,
  32.             //ObjectId = 5006,
  33.             //SelectionSet = 5007,
  34.             //Orientation = 5008,
  35.             //Point3d = 5009,
  36.             //Int32 = 5010,
  37.             //Void = 5014,
  38.             //ListBegin = 5016,
  39.             //ListEnd = 5017,
  40.             //DottedPair = 5018,
  41.             //Nil = 5019,
  42.             //T_atom = 5021
  43.         }
  44.     }
  45. }
  1. (defun c:lisp1(a) (princ (strcat "C#传入lisp参数为:" (rtos a) "\n")) 456)
关于C#调用lisp的源码好像较少,我弄了个超简单的,给需要的朋友
评分
参与人数 1D豆 +5 收起 理由
marting + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2021-2-1 16:29:01 | 显示全部楼层
谢谢楼主分享,学习了
发表于 2021-2-2 08:01:57 | 显示全部楼层
谢谢分享
发表于 2021-2-2 10:22:42 | 显示全部楼层
谢谢楼主分享,学习了
发表于 2023-12-22 14:58:51 | 显示全部楼层
using System;
using System.Runtime.InteropServices;
[assembly: CommandClass(typeof(Sample.CH6_8_3))]
namespace Sample
    class CH6_8_3
        [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedInvoke")]
        private static extern int acedInvoke(IntPtr args, out IntPtr result);
        public static ResultBuffer InvokeLisp(ResultBuffer args, ref int stat)
            IntPtr rb = IntPtr.Zero;
            stat = acedInvoke(args.UnmanagedObject, out rb);
            if (stat == (int)PromptStatus.OK && rb != IntPtr.Zero)
                return (ResultBuffer)DisposableWrapper.Create(typeof(ResultBuffer), rb, true);
            return null;
        [CommandMethod("CallLispFunction")]
        public void CallLispFunction()
            ResultBuffer args = new ResultBuffer();
            int stat = 0;
            args.Add(new TypedValue((int)LispDataType.Text, "c:CallByNet"));
            ResultBuffer res = InvokeLisp(args, ref stat);
        [LispFunction("CallByLispFunction")]
        public static void CallByLispFunction(ResultBuffer rbArgs)
            foreach (TypedValue rb in rbArgs)
                if (rb.TypeCode == (int)Autodesk.AutoCAD.Runtime.LispDataType.Text)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(rb.Value.ToString());
(defun c:CallByNet()
  (setq p1 (getpoint"输入第一点:"))
  (setq p2 (getpoint"输入第二点:"))
  (command "line" p1 p2 "")
(defun c:CallNet()
  (setq t1 "BimCad.org")
  (setq t2 "数字建筑")
  (CallByLisp t1 t2)
书上抄来的
GMT+8, 2026-11-22 11:05 , Processed in 0.619929 second(s), 17 queries , Gzip On, File On.
