查看: 6552|回复: 3
[图块] AcDbBlockReference::explode 失败
发表于 2021-2-2 10:00:01 | 显示全部楼层 |阅读模式
AcDbBlockReference::explode fails
问题:
Why does AcDbBlockReference::explode produce incorrect results if there are
AcDbText or AcDbAttribute definition entities in the block that is exploded?
解答:
This isa known problem that is desribed in DevNote #TS36113.
AcDbBlockReference::explode internally calls AcDbText::getTransformedCopy that
produces incorrect results. The code below uses the code in DevNote #TS36113 to
explode an AcDbBlockReference correctly.
  1. Acad::ErrorStatus safeExplode(const AcDbBlockReference* pRef,AcDbVoidPtrArray&entitySet)
  2. {
  3. AcDbBlockTableRecord* pBTR;
  4. Acad::ErrorStatus es;
  5. if ((es = acdbOpenAcDbObject((AcDbObject*&)pBTR, pRef->blockTableRecord(), AcDb::kForRead)) == Acad::eOk)
  6. {
  7.   AcDbBlockTableRecordIterator* pIterator;
  8.   if (pBTR->newIterator(pIterator) == Acad::eOk)
  9.   {
  10.    AcGeMatrix3d xform = pRef->blockTransform();
  11.    AcGePoint3d pt3dBlkOrigin = pBTR->origin();
  12.    if (pt3dBlkOrigin != AcGePoint3d::kOrigin)
  13.    {
  14.     AcGeVector3d xformOrigin = xform.translation();
  15.     AcGeVector3d vectorOrigin(pt3dBlkOrigin.x,pt3dBlkOrigin.y,0.0);
  16.     vectorOrigin.transformBy(xform);
  17.     xformOrigin -= vectorOrigin;
  18.     xform.setTranslation(xformOrigin);
  19.    }
  20.    pIterator->start();
  21.    while (!pIterator->done())
  22.    {
  23.     AcDbEntity* pEntity;
  24.     if (pIterator->getEntity(pEntity, AcDb::kForRead) == Acad::eOk)
  25.     {
  26.       // If pEntity does not implement getTransformedCopy()
  27.       // or explode() methods, we should simply ignore
  28.       // that entity and continue to step into next entity
  29.       // instead of exit prematurely. Most operations such
  30.       // as BHATCH depends on complete iteration through
  31.       // the entire block entities.
  32.       AcDbEntity* pNewEntity;
  33.       AcDbText* pText =NULL;
  34.       if (pText=AcDbText::cast(pEntity))
  35.        es = AdskUtil::safeGetTransformedCopy(pText,xform, pNewEntity);
  36.       else
  37.       es = pEntity->getTransformedCopy(xform, pNewEntity);
  38.       if (es==Acad::eOk)
  39.       {
  40.       entitySet.append(pNewEntity);
  41.       }
  42.       else if (Acad::eExplodeBeforeTransform == es)
  43.       {
  44.       AcDbVoidPtrArray explSet;
  45.       if (Acad::eOk == pEntity->explode(explSet))
  46.       {
  47.        for (int i = 0; i < explSet.length(); i++)
  48.        {
  49.         AcDbEntity* pObj = (AcDbEntity*)explSet;
  50.         if (Acad::eOk == pObj->getTransformedCopy( xform, pNewEntity))
  51.         {
  52.          entitySet.append(pNewEntity);
  53.         }
  54.         delete pObj;
  55.        }
  56.       }
  57.      }
  58.      else if (Acad::eCopyFailed == es)
  59.      {
  60.       AcDbVoidPtrArray explSet;
  61.       if (Acad::eOk == pEntity->explode(explSet))
  62.       {
  63.        for (int i = 0; i < explSet.length(); i++)
  64.        {
  65.         AcDbEntity* pObj = (AcDbEntity*)explSet;
  66.         if (Acad::eOk == pObj->transformBy(xform))
  67.         {
  68.          entitySet.append(pObj);
  69.         }
  70.        }
  71.       }
  72.      }
  73.      pEntity->close();
  74.     }
  75.     pIterator->step();
  76.    }
  77.    delete pIterator;
  78.   }
  79.   pBTR->close();
  80. }
  81. return es;
  82. }
发表于 2022-11-5 22:28:28 | 显示全部楼层
请问safeGetTransformedCopy这个函数是自定义的吗?源码可否发一下
对AcDbText的安全的transformedCopy方法  详情 回复 发表于 2023-11-14 03:08
发表于 2023-11-14 03:08:58 | 显示全部楼层
  1. Acad::ErrorStatus XdDbUtils::safeGetTransformedCopy(const AcDbText* pText,
  2.        const AcGeMatrix3d xform, AcDbEntity*& pNewEntity)
  3. {
  4.         static AcDbText text;
  5.         Acad::ErrorStatus es;
  6.         text.copyFrom(pText);
  7.         AcGePoint3d posorig(text.position());
  8.         AcGePoint3d alignorig(text.alignmentPoint());
  9.         AcGePoint3d pos,align;
  10.         AcGeVector3d norm(text.normal());
  11.         acdbWcs2Ecs(asDblArray(posorig),asDblArray(pos),asDblArray(norm),
  12.                 Adesk::kFalse);
  13.         double elev = pos.z;
  14.         if (fabs(elev)>1E-10)
  15.         {
  16.                 pos.z = 0;
  17.                 align.z =0;
  18.                 acdbEcs2Wcs(asDblArray(pos),asDblArray(pos),asDblArray(norm),
  19.                         Adesk::kFalse);
  20.                 acdbEcs2Wcs(asDblArray(align),asDblArray(align),asDblArray(norm),
  21.                         Adesk::kFalse);
  22.                 text.setPosition(pos);
  23.                 text.setAlignmentPoint(align);
  24.         }
  25.         if ((es = text.getTransformedCopy(xform,pNewEntity))==Acad::eOk)
  26.         {
  27.                 AcDbText* pNewText = NULL;
  28.                 if ((pNewText = AcDbText::cast(pNewEntity)) && fabs(elev)>1E-10)
  29.                 {
  30.                         posorig.transformBy(xform);
  31.                         alignorig.transformBy(xform);
  32.                         pNewText->setPosition(posorig);
  33.                         pNewText->setAlignmentPoint(alignorig);
  34.                 }
  35.         }
  36.         return es;
  37. }
谢谢回复,我学习一下  详情 回复 发表于 2023-11-27 09:00
发表于 2023-11-27 09:00:00 | 显示全部楼层
谢谢回复,我学习一下
GMT+8, 2026-11-22 07:19 , Processed in 0.275519 second(s), 6 queries , Gzip On, File On.
