查看: 2528|回复: 1
[每日一码] 标注镜像后,调整文字到正确的显示
发表于 2021-2-3 16:51:58 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (if (and (setq e (car (xdrx-entsel "\n拾取尺寸<退出>:" '((0 . "dim*")))))
  3.            (setq normal (xdrx-getpropertyvalue e "normal"))
  4.            (not        (xdrx-vector-iscodirectional normal (getvar "viewdir")))
  5.       )
  6.     (progn
  7.       (setq ang        (xdrx-getpropertyvalue e "rotation")
  8.             p1        (xdrx-getpropertyvalue e "dimlinepoint")
  9.             ang        (- pi ang)
  10.       )
  11.       (xdrx-setpropertyvalue
  12.         e               "normal"              '(0 0 1)             "rotation"
  13.         ang               "dimlinepoint" p1
  14.         "horizontalrotation"              0.0
  15.        )
  16.     )
  17.   )
  18.   (princ)
  19. )
发表于 2021-2-4 06:41:17 | 显示全部楼层
这个问题有时候的确很烦
GMT+8, 2026-11-22 09:15 , Processed in 0.334126 second(s), 12 queries , Gzip On, File On.
