查看: 1942|回复: 3
[每日一码] 规则重定义 WorldDraw显示重定义
已领礼包: 57个
发表于 2021-3-1 10:16:23 | 显示全部楼层 |阅读模式
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.DatabaseServices;
using TBPublicMethod;
using Autodesk.AutoCAD.Runtime;
using DotNetARX;
using SuperNetARX;
using Autodesk.AutoCAD.ApplicationServices;
using System;
namespace TestCommand
    public class OverrulePoly: DrawableOverrule
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            Autodesk.AutoCAD.DatabaseServices.Polyline pl = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline;
            double dLen = pl.Length;
            double dScale = 0.5;
            if (dLen < 10000) dScale = 0.05;
            else if (dLen < 30000) dScale = 0.28;
            else if (dLen < 50000) dScale = 0.4;
            else if (dLen < 100000) dScale = 0.45;
            Point3d ptRes = pl.GetPointAtDist(dLen * dScale);
            //string strName = "疏散路径距离:" /*pl.GetTextData("Name") */ + (dLen/1000).ToString("N2") + "m";
            short stOri = wd.SubEntityTraits.Color;
            ResultBuffer rb = pl.GetXDataForApplication("TYPolyXData");
            if (rb == null)
                return base.WorldDraw(drawable, wd);
            //文字内容
            string strTitle = ":";
            if (rb.AsArray() != null && rb.AsArray().Count() > 1)
                strTitle = rb.AsArray()[1].Value.ToString() + ":"; //"疏散路径距离:";
            string strName = strTitle + (dLen / 1000).ToString("N2") + "m";
            //文字大小
            double dTxtSize = 5;
            if (rb.AsArray() != null && rb.AsArray().Count() > 2)
                dTxtSize = (double)rb.AsArray()[2].Value; //"疏散路径距离:";
            //文字颜色
            short st = stOri;
            if (rb.AsArray() != null && rb.AsArray().Count() > 3)
                st = (short)rb.AsArray()[3].Value;
            wd.SubEntityTraits.Color = st;
            Vector3d vec = ComputeDir(pl, ptRes);
            Matrix3d matrix = Matrix3d.Rotation(Math.PI / 2, Vector3d.ZAxis, ptRes);
            ptRes += vec.TransformBy(matrix).GetUnitVector() * dTxtSize * 40;
            //ObjectId txtId = CreateTextStyle("微软雅黑12", "微软雅黑");
            //TextStyle textStyle = txtId.GetObject(OpenMode.ForRead) as TextStyle;
            //TextStyle textStyle = new TextStyle();
            //textStyle.FromTextStyleTableRecord("AAD-HT");
                TextSize = dTxtSize * 80,
                StyleName = "TYTextStyle",
                FileName = "微软雅黑",
                BigFontFileName = ""
            wd.Geometry.Text(ptRes, Vector3d.ZAxis, vec, strName, true, textStyle);
            //wd.Geometry.Text(ptRes, Vector3d.ZAxis, vec, 1000, 0.9 ,0, strName);
            //本身
            //wd.Geometry.Draw(pl);
            //wd.Geometry.Polyline(pl,0,0);
            //return true;
            //圆弧
            //wd.Geometry.CircularArc(startPoint, dLen, line.Normal, delta, Math.PI / 2, ArcType.ArcSimple);
            //wd.Geometry.CircularArc(startPoint,pt3,endPoint, ArcType.ArcSimple);
            //绘制直线本身
        public override bool IsApplicable(RXObject overruledSubject)
            Autodesk.AutoCAD.DatabaseServices.Polyline polyline = overruledSubject as Autodesk.AutoCAD.DatabaseServices.Polyline;
            if (polyline != null && polyline.Layer == "0A-A-TY-PL")
                return true;
            else
                return false;
        private Vector3d ComputeDir(Autodesk.AutoCAD.DatabaseServices.Polyline pl, Point3d pt)
            Vector3d vecDir = new Vector3d(1, 0, 0);
            Point3dCollection gripPts = pl.GetEntityGripPoint();
            gripPts.ClearCenterPt(1);
            for(int i = 0; i < gripPts.Count-1; i++)
                LineSegment3d ln = new LineSegment3d(gripPts[i],gripPts[i+1]);
                PointOnCurve3d ptOnCrv3d = ln.GetClosestPointTo(pt);
                double dDis = ptOnCrv3d.Point.DistanceTo(pt);
                if(dDis < 1e-4)
                    vecDir = ln.Direction;
                    return vecDir;
            return vecDir;
        private ObjectId CreateTextStyle(string strName, string fontFileName, string bigFontFileName = "")
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                TextStyleTable tst = db.TextStyleTableId.GetObject(OpenMode.ForRead) as TextStyleTable;
                if (!tst.Has(strName))
                    TextStyleTableRecord tstr = new TextStyleTableRecord();
                    tstr.Name = strName;
                    tstr.FileName = fontFileName;
                    tstr.BigFontFileName = bigFontFileName;
                    tst.UpgradeOpen();
                    tst.Add(tstr);
                    db.TransactionManager.AddNewlyCreatedDBObject(tstr, true);
                    tst.DowngradeOpen();
                trans.Commit();
                return tst[strName];
        private Entity CreateTCHText()
            Entity entRes = null;
                ListenNewCreateObj listen = new ListenNewCreateObj();
                listen.StartToGetNewCreateEnt(db);
                ResultBuffer rb = new ResultBuffer();
                rb.Add(new TypedValue((int)ResBufCode.String, "TText"));
                rb.Add(new TypedValue((int)ResBufCode.Point3d, Point3d.Origin));
                rb.Add(new TypedValue((int)ResBufCode.String, ""));
                TestClass.resBuffer = rb;
                Application.DocumentManager.MdiActiveDocument.SendCommand("TYSendAcedCmd\n");
                ObjectIdCollection ids = new ObjectIdCollection();
                listen.GetAllNewIds(ids,db);
                if(ids.Count == 1)
                    entRes = ids[0].GetObject(OpenMode.ForWrite) as Entity;
                trans.Commit();
            return entRes;
添加规则重定义
//规则重定义对象
        private static OverrulePoly theOverride;
        [CommandMethod("TYOverrulePoly")]
        public static void TYOverrulePoly()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
                //Entity ent;
                try
                    if (theOverride == null)
                        theOverride = new OverrulePoly();
                        //添加
                        Overrule.AddOverrule(RXObject.GetClass(typeof(Polyline)), theOverride, false);
                        //theOverride.SetXDataFilter("TYPolyline");
                        theOverride.SetCustomFilter();
                    Overrule.Overruling = true;//开启
                    Application.DocumentManager.MdiActiveDocument.Editor.Regen();
                catch (System.Exception ex)
                    ed.WriteMessage(ex.Message + " " + ex.StackTrace + "\n");
                trans.Commit();
已领礼包: 58个
发表于 2021-3-10 20:50:00 | 显示全部楼层
天正的疏散路径是自定义对象还是规则重定义?
已领礼包: 57个
 楼主| 发表于 2021-3-11 16:53:35 | 显示全部楼层
没有看到天正的疏散路径 这个东西啊,天正的东西应该都是自定义实体吧。
已领礼包: 58个
发表于 2021-3-11 18:59:57 | 显示全部楼层
嗯 我最近也写了一个疏散路径  比较简单 用的也是规则重定义
文字在曲线中点
GMT+8, 2026-11-3 13:57 , Processed in 0.590981 second(s), 34 queries , Gzip On.
