查看: 1574|回复: 0
[求助] 添加到工作文件支持搜索路径!列表有缺陷,求助~
已领礼包: 20个
发表于 2021-5-8 11:50:51 | 显示全部楼层 |阅读模式
;;lyy 支持appload加载、命令行(load "xx")加载和直接拖曳加载
(vl-load-com)
(defun set_path (/ str n1 n2)
(while (/= 0 (getvar "cmdactive")) (command))
(princ "n")
(setq str (getvar "lastprompt"))
(if (wcmatch (strcase str) "*(LOAD "*")
    (setq n1 (vl-string-search "(LOAD "" str)
          n2 (vl-string-search "")" str)
          str (substr str (+ n1 8) (- n2 n1 7))
    (setq str
      (vl-registry-read "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSaveMRU\*"
        (substr (vl-registry-read "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSaveMRU\*" "MRUList") 1 1)
(setenv "ACAD" (strcat (getenv "ACAD") ";" (vl-filename-directory str)))
(set_path)
(setq set_path nil)
这个是网上搜索
使用提示缺陷,
哪位大侠能否出手相助!
希望能实现拖拽进CAD,自动添加该LISP的文件夹路径,到工作支持文件搜索路径!
GMT+8, 2026-11-3 10:31 , Processed in 0.378878 second(s), 28 queries , Gzip On.
