查看: 1669|回复: 1
[求助] region生成的边界缺少一段
已领礼包: 58个
发表于 2021-6-16 08:56:32 | 显示全部楼层 |阅读模式
  1. //为什么regionregion生成的边界会缺少一段
复制代码
  1. [CommandMethod("testregion")]
  2.         public void RegionSubstr()
  3.         {
  4.             var doc = Application.DocumentManager.MdiActiveDocument;
  5.             var db = doc.Database;
  6.             var ed = doc.Editor;
  7.             //var ent1 = ed.GetEntity("\nSelect Curve");
  8.             //建立选择集过滤
  9.             ResultBuffer tv = new ResultBuffer();                                tv.Add(new TypedValue(0, "*line"));
  10.             SelectionFilter fil = new SelectionFilter(tv);
  11.             PromptSelectionOptions pso = new PromptSelectionOptions();
  12.             pso.MessageForAdding = "\n select curves:";
  13.             PromptSelectionResult psr = ed.GetSelection(pso, fil);
  14.             if (psr.Status != PromptStatus.OK)
  15.             {
  16.                 ed.WriteMessage("\n selection is null!");
  17.                 return;
  18.             }
  19.             PromptEntityResult ent = ed.GetEntity("\nselect curve to be substracted:");
  20.             using (var tr = db.TransactionManager.StartTransaction())
  21.             {
  22.                 BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  23.                 ObjectId oId = ent.ObjectId;
  24.                 Entity entity2 = tr.GetObject(oId, OpenMode.ForWrite) as Entity;
  25.                 var curveSegments = new DBObjectCollection();
  26.                 foreach (var id in psr.Value.GetObjectIds())
  27.                 {
  28.                     curveSegments.Add(tr.GetObject(id, OpenMode.ForRead) as Entity);
  29.                 }
  30.                 var regions = Region.CreateFromCurves(curveSegments);
  31.                 var region1 = regions[0] as Region;
  32.                 var region2 = Region.CreateFromCurves(new DBObjectCollection { entity2 })[0] as Region;
  33.                 if (region1 != null)
  34.                 {
  35.                     region1.BooleanOperation(BooleanOperationType.BoolSubtract, region2);
  36.                     Brep brep = new Brep(region1);
  37.                     BrepFaceCollection faces = brep.Faces;
  38.                     BoundaryLoop boundaryLoop = faces.First().Loops.First();
  39.                     Edge[] boundaryEdges = boundaryLoop.Edges.ToArray();
  40.                     Curve3d[] cv3 = new Curve3d[boundaryEdges.Count()];
  41.                     for (int i = 0; i < boundaryEdges.Count(); i++)
  42.                     {
  43.                         cv3 = (boundaryEdges.Curve as ExternalCurve3d).NativeCurve;
  44.                     }
  45.                     CompositeCurve3d cc3 = new CompositeCurve3d(cv3);
  46.                     var newCv1 = Curve.CreateFromGeCurve(cc3);
  47.                     newCv1.ColorIndex = 1;
  48.                     btr.AppendEntity(newCv1);
  49.                     tr.AddNewlyCreatedDBObject(newCv1, true);
  50.                 }
  51.                 tr.Commit();
  52.             }
  53.         }
GMT+8, 2026-11-3 11:16 , Processed in 0.530512 second(s), 30 queries , Gzip On.
