查看: 2277|回复: 5
[求助] lisp可否实现动态块动作编辑?
已领礼包: 212个
发表于 2021-6-27 10:05:54 | 显示全部楼层 |阅读模式
我想通过在块内修改线性参数的方式来改变阵列间距
求代码
再就是,动态块的动作属性是否可以用LIsp实现编辑
已领礼包: 4365个
发表于 2021-6-29 07:54:53 | 显示全部楼层
已领礼包: 4个
发表于 2021-6-29 08:12:37 | 显示全部楼层
  1. ; (DynamicProps (car (entsel)) "Pipe length" nil) get the Pipe length from a dynamic block
  2. ; (DynamicProps (car (entsel)) "" nil) get the properties from a dynamic block
  3. ; (DynamicProps (car (entsel)) "Pipe length" 2000.0) set the properties from a dynamic block
  4. (defun DynamicProps (ename propname value / obj prpL prp)
  5.   (vl-load-com)
  6.         ;(setq ename (car (entsel)))
  7.   (setq obj
  8.                 (if (= (type ename) 'VLA-OBJECT)
  9.                         ename
  10.                         (vlax-ename->vla-object ename)
  11.                 )
  12.         )
  13.   (if vla-getdynamicblockproperties
  14.                 (setq prpL (vlax-invoke obj 'getdynamicblockproperties))
  15.         )
  16.         ;(setq propname "查寻")
  17.         ;(setq value "20")
  18.   (setq return
  19.     (if (setq prp (vl-remove-if-not (function (lambda(x)
  20.        (= (vlax-get-property x 'PropertyName) propname)
  21.        )) prpL))
  22.       (mapcar
  23.                                 (function (lambda(v)
  24.        (if (and (/= value nil) (vlax-property-available-p v 'Value) (/= (type value)'LIST))
  25.        (progn (vlax-put-property v 'Value value) (vla-update obj))
  26.        )
  27.        (if (and (vlax-property-available-p v 'AllowedValues) (vlax-get v 'AllowedValues))
  28.        (list (vlax-get v 'Value) (vlax-get v 'AllowedValues))
  29.        (vlax-get v 'Value)
  30.        )
  31.                   ))
  32.                                 prp
  33.                         )
  34.       (mapcar
  35.                                 (function (lambda(v)
  36.        (list (vla-get-propertyName v)(vlax-get v 'Value) v)
  37.        ))
  38.                                 prpL
  39.                         )
  40.     )
  41.   )
  42.   return
  43. )
  44. (DynamicProps (car (entsel)) "距离" nil)
  45. (DynamicProps (car (entsel)) "" nil)
  46. (DynamicProps (car (entsel)) "查寻" "50")
  47. (DynamicProps (car (entsel)) "可见性" "2")
  48. (= (vlax-get-property (nth 12 prpL) 'PropertyName) propname)
  49. (vlax-property-available-p (nth 0 prp) 'Value)
  50. (vlax-put-property (nth 0 prp) 'Value value)
  51. (vlax-property-available-p (nth 0 prp) 'AllowedValues)
  52. (vlax-get (nth 0 prp) 'AllowedValues)
  53. (vla-get-propertyName (nth 0 prpL))
  54. (vlax-get (nth 0 prpL) 'Value)
  55. (length return)
  56. (assoc "查寻" return)
  57. (DynamicProps (car (entsel)) "查寻" 50)
这是直接改参数值得,我想编辑动态块的动作属性 例如阵列动作的间距  详情 回复 发表于 2021-7-11 09:22
已领礼包: 212个
 楼主| 发表于 2021-7-11 09:22:20 | 显示全部楼层
已领礼包: 10个
发表于 2021-7-27 16:14:43 | 显示全部楼层
http://lee-mac.com/dynamicblockfunctions.html 这个应该会对你有一定帮助
已领礼包: 22个
发表于 2021-7-28 00:41:27 | 显示全部楼层
学习真是无止境啊
GMT+8, 2026-11-3 06:36 , Processed in 0.421505 second(s), 42 queries , Gzip On.
