查看: 1373|回复: 1
[求助] 尺寸标注重叠检查
发表于 2021-7-16 21:48:59 | 显示全部楼层 |阅读模式
请高手帮忙完善一下,这个代码。
(defun c:cccd(/ E SS SS1 SS2 N P1 P2 LSTSS1 LSTSS2 SSS)
  (defun getdxf(s num)(cdr(assoc num s)))
  (setq ss(ssget '((0  . "dimension"))) n 0 SSS (SSADD))
  (repeat (sslength ss)
    (setq e(ssname ss n)
          s(entget e)
          p1(getdxf s 10)
          clz1(abs(-(car(getdxf s 13))(car(getdxf s 14))))
          clz2(abs(-(cadr(getdxf s 13))(cadr(getdxf s 14))))
          P2(list (- (car p1)clz1)(- (cadr p1)clz2)(caddr p1))
    (SETQ SS1(SSGET "C" P1 P1 '((0  . "dimension")))
          LSTSS1(SS2LST SS1)
          SS2(SSGET "C" P2  P2 '((0  . "dimension")))
          LSTSS2(SS2LST SS2)
    (if (and ss1 ss2)
      (progn
    (SSDEL E SS1)
    (SSDEL E SS2)
    (IF (AND (EQUAL LSTSS1 LSTSS2)
             (>(LENGTH LSTSS1)0)
             (>(LENGTH LSTSS2)0)
      (repeat(setq m(sslength ss1))
             (SSADD (ssname ss1(setq m(1- m))) SSS)
(setq n(1+ n))
(SSSETFIRST SSS SSS)
(princ)
(defun ss2lst (ss / nn ee lst)
(repeat (setq nn (sslength ss))
  (setq  lst (cons (ssname ss (setq nn (1- nn))) lst))
GMT+8, 2026-11-3 11:11 , Processed in 0.411304 second(s), 34 queries , Gzip On.
